Weights made just for model airplanes
    October 2009
Posted by Khalee2 on Friday, March 22, 2013 1:43 PM
Does anybody make weights just for model airplanes? Model I am working on 1/72 says to put 31 grams in the nose But there is not a lot of room once everything is put in and closed up.
What should I use BB's and how many ?Should just poor them in till I fill the space?
Thanks
Posted by ajlafleche on Friday, March 22, 2013 2:02 PM
Any open space forward of the main gear can accomodate weights. You can use just about anything. I've regularly stuffed window putty into nose cones, under cockpits, behind radial engines. If you have fuel tanks under the wings that extend beyond the amin gear, you can use that space as well.
    October 2008
Posted by eatthis on Friday, March 22, 2013 2:38 PM
dont forget about leverage ie the further away you put the weight from the pivot (the wheel) the less weight youll need
snow + 4wd + escessive hp = :)  http://www.youtube.com/watch?v=x7egUIS70YM
    October 2008
Posted by padakr on Friday, March 22, 2013 2:39 PM
I use fishing sinkers, the inexpensive split ones.  They are fairly dense, so you usually don't need a lot.  Put a few into the nose and cover with white glue (don't use plastic cement - I made that mistake early on and the nose warpped).
Paul
Posted by Texgunner on Friday, March 22, 2013 2:58 PM
In addition to mixing bird-shot with 2-part epoxy and then packing that paste into voids, I also find that spent bullets or pulled bullets from dud rounds really work well.  I dig them out of the berm at my shooting range, or use new, pulled projectiles.  The 9mm and .45acp bullets fit really well in nose cones and prop spinners and rifle bullets are typically longer and fit in more spaces. They can be glued in place with epoxy.  Gary
ymmv.Big Smile
"All you mugs need to get busy building, and post pics!"
    March 2005
Posted by TarnShip on Friday, March 22, 2013 3:32 PM
Terry's email is at the bottom of this product page
modelingmadness.com/.../td2006prices.htm
Rex
almost gone
    February 2006
Posted by ruddratt on Friday, March 22, 2013 8:44 PM
This is all I use. May be pricey, but I've yet to find anything that works as well....
http://www.golfsmith.com/product/30079088/golfmechanix-high-density-swing-weighting-tungsten-powder---4oz
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
Posted by Don Stauffer on Saturday, March 23, 2013 9:15 AM
There are some products made primarily for weight for Pinebox Derby cars that may work for noseweights.  Seems to me someone made a metal-powder-weighted putty.  Some of the larger hobby shops also carry Pinebox Derby kits and accessories.
    September 2010
Posted by mikeymize on Saturday, March 23, 2013 9:56 AM
I was having the same problem with an F-86. The directions said to use 15g. in the nose section. I have used lead shot secured with putty in the past but it's tedious to take them out of shotgun shells. Not to mention I had to be really careful. Then I came across these weights at the LHS. I included a pic of where I located them in the fwd fuselage just for perspective. They're 7 gm. each and have stick 'em on the back. $4.99 which I thought was reasonable. Just another option for you........
"Time you enjoy wasting is not wasted time".
    February 2007
Posted by Lodni Kranazon on Saturday, March 23, 2013 11:30 PM
Amazon can be your friend! =)
www.amazon.com/.../ref=sr_1_fkmr3_3
[Admiring Starbuck's space fighter] Cassiopeia: It's a perfect machine! Born to dance amongst the stars! Starbuck: Yeah, it's bumping into them that has me worried.
