Digital_Cowboy
I'm sure that most if not all of us know that chrome plated parts can't just be glued to styrene, that the chrome has to be removed or stripped first before gluing. Particularly when using the "old standard" Testors (or similar) glue that "melts" the plastic together. My question is, if one used a CA or epoxy, does the chrome have to be removed or stripped first?
My next question is why does it seem like so many here go to extremes to remove ALL of the chrome from parts? And/or why don't companies provide parts with and without chrome? That way people will have the choice of using the chromed or unchromed parts. Does one need to remove all of the chrome in order to paint the part?
And another good question is that considering that plastic does NOT (at least the last time I checked) conduct electricity then how do they plate it with chrome?!?!
If using CA or epoxy, you don't need to do the chrome removal, but you have to remember that the bond will be between the chrome-CA-plastic or if the plastic is painted, then chrome-CA-paint. You won't have as strong a bond as you would with plastic-to-plastic when regular cement "melts" them into one.
When companies chrome the entire sprue, there is often mold seams that are visible that will need to be removed. Plus most chrome looks too shiny and appear fake. There are now better ways to paint the chrome on that look more realistic. Additionally, not everything chromed on the sprue needs to be as shiny. A shift lever may be bare metal, the bumper polished aluminum, etc.
You can google that answer for the chrome plating. I know there are several companies that will chrome scratchbuilt or re-chrome parts you've cleaned up. They send you a kit to mount your pieces to. They probably have information on their sites that describe the process.
