What putty are you using?
    May 2013
Posted by R-4360 on Saturday, May 25, 2013 8:38 PM
Not fond of Squadron Green Stuff, or the white stuff either. I used to like Dr Microtools red putty...but they're gone. Years ago, I liked Swiss green putty - haven't seen that in a LONG time.
What are you using? Why do yoi like it?
    December 2006
Posted by Jester75 on Saturday, May 25, 2013 8:54 PM
Bondo Glazing and Spot putty from the automotive parts store. Six dollar tubes will last for a really really long time and it doesn't seem to dry out like a lot of others.
Eric
fox
    January 2007
Posted by fox on Saturday, May 25, 2013 9:00 PM
I use "Bondo Glazing & Spot Putty" (Red). Available in most Auto Supply stores. Comes in a 16 oz. tube. Lasts a long time. Goes on easily, dries in 10 to 15 minutes, and is very easy to sand with either regular sand paper or wet or dry paper.
Used to use "Acryl Blue". It was also available in Auto Supply stores. Great to use and the light blue color was easy to cover. It isn't available around here any more.
Jim Captain
 Main WIP:
    August 2008
Posted by tankerbuilder on Sunday, May 26, 2013 9:48 AM
I still use " ACRYL BLUE " and " BONDO " spot and GLAZING putty ,  both red and green  . The green and sometimes the ACRYL BLUE are tender in delicate spots . I still use the  "old " SQUADRON putties too . I find ALL of them to do what I want  , when I want . The thing to remember is you build them up in almost paper thin layers and they will always work as planned . Scratchbuilt ships sometimes require more than regular projects .          Tanker-builder
mgh
    May 2011
Posted by mgh on Sunday, May 26, 2013 11:01 AM
I use Testors Contour Putty.  I like it because it thins very nicely will plain rubbing alcohol, and can be sanded very easily.  Wet sanding takes it off in a hurry, so you have to be careful.
    December 2006
Posted by Fly-n-hi on Sunday, May 26, 2013 3:39 PM
Aves Apoxie Sculpt, Mr. Dissolved Putty and Mr. Surfacer 500.
    January 2003
Posted by TomZ2 on Sunday, May 26, 2013 4:05 PM
http://www.avesstudio.com/index.php?option=com_content&view=frontpage&Itemid=1
Apoxie Sculpt vs.  Milliput: One group claims that Apoxie Sculpt is stronger than Milliput and smooths with a wet finger. The other crowd claims that Milliput holds detail better. (A splinter clique says Fixit® Sculpt (also by Aves Studio) is better than either of them.)
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    April 2013
Posted by SchattenSpartan on Sunday, May 26, 2013 4:11 PM
I use Vallejo's putty:
I don't know how other putties behave when you sand them, but you can only wet-sand that stuff. It's awesome to fill any sort of gaps though (it has such a nice plastic tip for precise apllication)
Cheers, Clemens
    March 2005
Posted by TarnShip on Sunday, May 26, 2013 4:57 PM
I am a Red Spot Putty guy
I get mine at an automotive chain, and since it is available in a 4.5 oz tube,,,,,,that is the one I get because if I keep it too long, I won't have to throw out as much unused putty someday
I also use a little Mr Primer Surfacer 1000 as a very thin putty, because just as Tanker says above,,,,building up very thin layers is the way to go,,,,,,,and with Mr P, there is no choice, it can't go on thickly, lol,,,,,,,,,,this stuff is great for filling in join lines that seem too small for a glop of putty, but, too big to just fill when I prime
a tip,,,,,,,,,sanding is the enemy of keeping the detail,,,,,,so, the thinner you can go with your Putty and Primer, the less sanding you have to do, that makes for less risk of having to lose or replace detail
Rex
almost gone
    April 2013
Posted by SchattenSpartan on Sunday, May 26, 2013 5:04 PM
It seems like I have to get me some Mr surfacer 500 or 1000 then... Only problem is: My LHS doesn't carry them. Any Ideas where I can get some of it?
Clemens
