Painting Prop's
    July 2013
Painting Prop's
Posted by Niccolai46 on Monday, August 5, 2013 11:26 AM
To all my friends in the FSM forums,   Hi guys! I need some advice regarding the prop on the DR.1 Fokker I'm currently building. The main question is.... HOW DO I GET THIS THING TO LOOK LIKE IT'S WOOD!!!! I have seen many of pictures of these planes and they all had wooden props. I'm wondering if there is a certain technique to this or if possibly these builders are actually making real wood props for their planes?It seems possible but unlikely. ALSO, (I don't know if this is the right forum for this question but here goes), IS THERE A WAY TO POST PIC'S DIRECTLY FROM MY SMART PHONE?
I would appreciate any help,THANX!....Nick
Tags: airplanes
    September 2003
Posted by checkmateking02 on Monday, August 5, 2013 3:05 PM
Here's what I did to get wood grain on a cockpit floor for a 1/72 scale Pfalz DIII I was building.
I airbrushed with the floor with Model Master's enamel "Wood," and sprayed it with a clear coat.  The clear coat was to protect the original color and make the "streaks" apply smoothly.
When the "Wood" and clear coat were dry (like the next day), I thinned some darker brown acrylic craft paint and streaked it on with a small paint brush until I achieved a sort of grain-look.
Since this particular project was a resounding failure and I scrapped it all, I didn't get as far as the wooden propeller, but the technique I used on the floor might work on a prop.
Good luck, anyway!
Don't know anything about smart phones though--the dumb ones give me enough trouble.
    August 2008
Posted by tankerbuilder on Tuesday, August 6, 2013 8:21 AM
Hi :
  I use pretty much the same method with one twist (no pun intended ) I take the prop and paint it in dark brown and light tan ,  in barber pole style (almost ) Then I let it dry overnight , next day I take a thinner wetted rag , NOT SOAKED !  and drag it the length of the blades from hub to tip . After it looks right to me I let it dry again , overnight and then clearcoat it in MODEL MASTER GLOSS . All Paints used are model master ENAMELS , not ACRYLICS !   Tanker-Builder
    April 2006
Posted by waynec on Tuesday, August 6, 2013 12:09 PM
i use a coptic walnut alcohol pen. have to prime the surface first/
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    February 2015
Posted by Bick on Tuesday, August 6, 2013 4:56 PM
Simulating wood grain has always been a 'do I really have to' for me but look IN THIS THREAD for pics of the props on my V173. Nothing magic but it worked. Here's  quote from that thread of what I did:
"The props are done with craft acylics and Future floor finish. I mixed up some 'sand' color, airbrushed the blades with this as a base, then sorta dry brushed with a dark brown acrylic to mimic grain. Next was two airbrushed coats of Future tinted deep transparent yellow with food dye. The red, yellow, and blue bands were masked and sprayed with off the shelf acrylic craft paint. A final coat of straight Future finished the job. From hints gleaned from the web and from an artist friend of mine."
    April 2010
Posted by emelen on Friday, August 9, 2013 9:08 PM
I used a wood shaded paint, tan or light brown, pour a little on a plastic deli tub lid (I use these for palettes all the time) Next pour a little black or dark brown next to the first color .Here is the trick, take your brush get a little dark on the end dip on lid to take a little off now dip into your wood color and paint long straight strokes  The light and dark should not blend but kind of streak in a natural wood look  practice on the lid utill it looks right then jump on that prop When dry do all the clear stuff everyone does good luck, keep on gluing!
Posted by Don Stauffer on Saturday, August 10, 2013 9:20 AM
This is similar to  "dry brushing."  It is how I do props.  Dry brushing seems to be a passed fad but I find it useful for many places. With dry brushing the paint does not go down evenly, but in a streaked pattern which can look like grain.
Posted by wayne baker on Sunday, August 11, 2013 11:09 PM
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
