micro set and micro sol how to use
    August 2013
Posted by GerryM on Tuesday, August 20, 2013 11:15 AM
i would  like to  know the  best way to  use  these  products as using  for the first time
Posted by Don Stauffer on Wednesday, August 21, 2013 8:57 AM
Decal solvents are a frequent thread on the "decals" forum, so if you do not get the answers you are looking for here, I urge you to try that forum.
That said, I start with the micro set. It is pretty benign.  Only if the decal does not settle down well do I resort to a solvent (like Micro Sol).  Decal solvents are pretty mean stuff, so once you apply them you have to leave the surface alone until it is completely dry.  So- summary, start with Micro Set, only if that doesn't work go to the solvent.  Use as little as possible, and use great care.
Posted by Tojo72 on Wednesday, August 21, 2013 8:58 AM
Micro set,the blue bottle is brushed on the area where the decals going,it is also applied on top after the decal sets some
Micro sol,the red bottle is stronger,it can be applied on top of the decal to help it song down over raised details,or panel lines after the blue bottle stuff
    September 2011
Posted by falconmod on Wednesday, August 21, 2013 9:56 AM
And then if your decal is really really stubborn use walthers solveset on it and don't touch it what ever you do!  I've been using it alot on my last 2 models.  Good stuff but hot!
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    April 2009
Posted by Cadet Chuck on Thursday, August 22, 2013 11:17 AM
It is a bit frightening to watch your decal get all wrinkled up shortly after you apply  a solvent.  That's normal.  Just don't touch it, walk away and leave it alone overnight.  You will be pleased at how good it looks the next morning!
    December 2006
Posted by Fly-n-hi on Thursday, August 22, 2013 1:46 PM
Be careful!  Not all decals are equal.  Tamiya decals usually don't play well with Micro Sol, and I'm assuming other solvents.
    August 2013
Posted by jeffcsr on Thursday, August 22, 2013 3:21 PM
tagged to subscribe to this thread...  Bought this product but haven't used it yet.
Posted by Tojo72 on Thursday, August 22, 2013 4:14 PM
I wonder if GerryM is even interested in our answers,I mean no thank yous or any response.
Just one of my pet peeves on the forums,people answered you,just say thanks
    August 2005
Posted by Phil_H on Thursday, August 22, 2013 6:41 PM
It's important to note that when using a decal setting solvent, the surface to which the decal is to be applied must be glossy. This means that if the final finish is flat, you must apply a clear gloss to the model, apply the decals and then apply a clear flat finishing coat.
As noted above, when a setting solution is applied to a decal, it wrinkles and shrivels. If the underlying surface is flat (ie. not glossy), it will impart too much friction to allow the decal to settle itself and smooth out as the setting solution dries.
