Flat coat
    December 2006
Flat coat
Posted by sarge on Wednesday, December 11, 2013 7:28 PM
I am about ready to finish a Centurion with an airbrushed flat coat.  Except, I cannot use enamel or lacquer based products due to the smell and VOC's.  I've read on other forums that one part Tamiya flat base can be mixed with 3 parts future to achieve a flat finish.  Otherwise, the Tamiya FB goes chalky on its own.  Can anyone verify this and are their other products out there that can be used as non-volatile flat coats.
    November 2003
Posted by mississippivol on Wednesday, December 11, 2013 8:54 PM
I have used Tamiya's flat base with Future with some success, but you'll want to experiment with the ratios on a a scrap piece of plastic in order to get it the way you'll like.
Glenn
    November 2003
Posted by mississippivol on Wednesday, December 11, 2013 8:55 PM
Sorry I forgot this, but Testor's acryl line has a flat acrylic clearcoat that you won't have to mix.
    March 2010
Posted by Nathan T on Thursday, December 12, 2013 12:10 AM
Polyscale Flat, Gunze flat, Vallejo, Lifecolor, Italeri- all these are acrylic flat coats.(As well as MM acrylic mentioned above)
    July 2004
Posted by stikpusher on Thursday, December 12, 2013 1:25 AM
The Pollyscale line is discontinued. Once they are all sold out, no more is coming.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2012
Posted by Misty on Thursday, December 12, 2013 1:41 AM
If it is the x21 flat base you mean then it it not a flat coat at all but is designed to be mixed with gloss the give a flat/ semi flat finish.
Posted by Tojo72 on Thursday, December 12, 2013 6:23 AM
The Vallejo Acrylic Flat is good stuff,I like it
