model railroad scale equivalents
Posted by icit on Sunday, December 15, 2013 9:26 PM
what are the model to railroad scale equivalents?
ICIT
    January 2006
Posted by SprueOne on Sunday, December 15, 2013 10:24 PM
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    October 2005
Posted by CG Bob on Sunday, December 15, 2013 10:26 PM
O Scale (0 or Zero gauge) generally accepted as 1/48  scale, but items vary between 1/43  to 1/50 scale.
HO Scale (one Half of O) is 1/87 scale.
N Scale is 1/160 scale (Nine MM rail spacing)
G Gauge (AKA Gauge 1 or LGB) has a wide range of scales; most common are 1/20.3, 1/22.5, 1/24, 1/29, and. 1/32
    February 2007
Posted by mitsdude on Monday, December 16, 2013 1:34 AM
The problem I've found is that, for example, 1/48 from one company can be noticeably larger or smaller than 1/48 from another company. Enough of a difference that they would look strange in a diorama together.
    May 2006
Posted by Edgar on Monday, December 16, 2013 2:14 AM
Railway scales can be a mix of metric and Imperial, which leads to all sorts of confusion. The standard "OO" gauge is 4mm to the inch, or 1/76 scale, while "O" gauge is 7mm to the inch, and 1/43 scale. Gauge 1 is normally 1/32 scale (probably why kit manufacturers started producing what, at first glance, seems an odd scale.)
Posted by icit on Monday, December 16, 2013 6:28 AM
Thanks guys, I see that I will need to be very careful in this.
