Enamel & Lacquer removal ??
Dre
    June 2007
Posted by Dre on Monday, March 10, 2014 5:34 PM
I know this has been answered to death, but the search function doesn't seem to find the answers I seek-
So, what I can I use to strip fully cured enamels and lacquers from a kit without melting the plastic?   I seem to recall reading about either brake fluid, or brake dust cleaner to do this, as well as oven cleaner.
I can immerse the area that needs stripping, so that's a plus.  Oh, the paint is 2 years cured and has Tamiya tape melted into it (don't ask) if that matters.
Any pointers are appreciated.
    January 2012
Posted by Cdn Colin on Monday, March 10, 2014 6:34 PM
Have you tried methyl hydrate (wood alcohol)?
I build 1/48 scale WW2 fighters.
Have fun.
    August 2009
Posted by JOE RIX on Tuesday, March 11, 2014 8:14 AM
Dre, There is a product called ELO (Easy Lift Off) that is (was) made by Polly S that is specifically designed for removing paint from plastic without any ill effects. I believe it is now put out by Testors. The stuff works wonderfully. In fact I just recently used it to remove a section of paint on my 1/72 FW 190 that had met with an unfortunate decal removal incident. I removed a small area of the camo and repaired it successfully.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
Posted by Don Stauffer on Tuesday, March 11, 2014 9:15 AM
I know folks who use oven cleaner,  or a heavy duty cleaner like Green Stuff. Both are slow going and messy, but they do work.
    March 2010
Posted by Nathan T on Tuesday, March 11, 2014 12:46 PM
Gunze Mr. Color Lacquer thinner will remove both types of paint and is safe on plastic. No need to soak the model in it, just wet a paper towel and wipe it off.
    June 2013
Posted by RobGroot4 on Tuesday, March 11, 2014 7:19 PM
Not sure about plastic safety, but generic lacquer thinner will get even old enamel paint off.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
Dre
    June 2007
Posted by Dre on Wednesday, March 12, 2014 8:14 AM
Thanks for all the input, I appreciate it guys!
Posted by Don Stauffer on Wednesday, March 12, 2014 9:17 AM
I find generic lacquer thinner does craze most styrene.
Dre
    June 2007
Posted by Dre on Wednesday, March 12, 2014 9:23 AM
I was under the impression that lacquer thinner would be too hot for this as well, Don.
    September 2004
Posted by Borg R3-MC0 on Wednesday, March 12, 2014 9:32 AM
What ever you do, do not use laquer thinner! I tried it once (what was I thinking?) and the stuff melted the plastic witing seconds.
    January 2014
Posted by Silver on Saturday, March 15, 2014 6:22 PM
Oven cleaner spray.
