Vacuform clear parts help
    August 2013
Posted by Jay Jay on Tuesday, April 15, 2014 12:23 PM
Please help.
Does any 1 do vacuformed clear parts?   I have a nice 1/72 Hudson MK 1 that was partially started by a beginer who ruined the clear parts with excessive glue    I need some one to make 4 small curved parts including a thumbnail sized canopy so I can finish the aircraft.  I sucessfully made all the flat clear windows with Testors  clear glue but it won't do the curved windows.
    May 2009
Posted by Pawel on Tuesday, April 15, 2014 2:44 PM
Hello!
You basically have two options more than having someone do them for you - buy a replacement (there's a company called Falcon that could have something like that for you) or you do it yourself. The IPMS Stockholm website has an article that would show you how. If Falcon doesn't have the thing you need (worth checking) you need models of the parts you want made. You need to duplicate the parts as solid blocks of resin or plaster of paris or something like that and then the parts could be vacuformed. Hope this will do for a first pointer - good luck with your project and have a nice day
Paweł
www.vietnam.net.pl
    September 2004
Posted by Borg R3-MC0 on Wednesday, April 16, 2014 5:35 AM
If the form is not to difficult you can use the "heat-smash" methode.
First, make a master out of a suitable material.
Then heat some clear plastic and pull it over the master.
Here are some pics:
on the right, in this case a broken canopy, on the left a wooden frame with clear plastic. I heat that above a gas stove then pull it over the master:
    August 2013
Posted by Jay Jay on Wednesday, April 16, 2014 9:43 AM
Thanks guys for the advice.  The heat smash method seems the way to go because I just can't see paying $25.00 for  a replacement canopy on an $ 8.50 model, but I DO appreciate your input.
    November 2008
Posted by plasticjunkie on Wednesday, April 16, 2014 11:20 AM
I remember watching a video where a shop vac is used along with pegboard. I have to look for it as I may very well need to vac form the long greenhouse canopy for a 1/72 scale Jake. I can't find any vac formed canopies for it.
 GIFMaker.org_jy_Ayj_O
    March 2010
Posted by Nathan T on Wednesday, April 16, 2014 11:42 AM
Squadron may have a canopy available? They usually only cost 5 to 8 bucks.
Nice pic there Borg!
    November 2008
Posted by plasticjunkie on Wednesday, April 16, 2014 1:54 PM
Nathan
That's the first place I looked in and nothing for the Jake. Falcon Canopies makes a set but it's $26!
