Spitfire - About 3 years ago, a fellow Forum member read something I wrote about someday wanting to try an airbrush after 64 years of hand brushing and using rattle cans. He made me an offer I couldn't refuse. An Aztek A3408 set complete(only used a couple of times), in the box, with extra tips, 2 cans of propellant, and 15 jars of Tamiya paint for $50.00. After I got it, I was scared to death to try it out.
It wasn't a difficult transition, but it took me a while to get the hang of the double action airbrush. For about a year, I practiced on old donor models whose only purpose was to try things out on. As I got used to the airbrush, the finishes got better (IMO). Last year, I got up the courage to use the airbrush on some models that I was entering in shows. I have received 5 awards between last year and this year, which I think is due to the finish on the models. I repainted one model with the Aztek that I took to a few shows but failed to win and at the next show, it won a second place. Sooooooo, I'd say that it is an improvement over the rattle cans and brushes. How much of an improvement is hard to say because I'm still on the learning curve.
At a show last year, one of my raffle tickets number was called and the prize was an Iwata Revolution CR airbrush set. I hooked it up and tried it over the winter. There was a difference between the two brushes and I think that time will tell which airbrush I prefer. A couple of weeks ago, I set up a lot of things that wanted to paint and being able to use my wife's compressor for the whole day was great. I set up both brushes with the same color and sprayed 1/2 of a donor with one and 1/2 with the other. I think I had better control with the Iwata and the finish was a little better.
As I said above,switching to Vallejo paints solved a lot of the problems that I had and makes the use of any airbrush easier. No thinning, no build-up on the needles and sooooooo easy to clean. Some like other airbrushes and other paints. So far, this is what is working for me.
Hope that this helps. Give me a shout if you need any other info.
Jim
Main WIP:
On the Bench: Artesania Latina (aka) Artists in the Latrine 1/75 Bluenose II
