I need a drying box . My basic ideal would be .
1 storage box
2 , temp. controller . I have
3. heating pad . Main reason for heating pad safe .
I would lay heating pad on bottom of storage box. make a shelf .( not sure yet )
Then plug heating pad into my temp controller( probe inside upper part of box . . Set that about 90 .
Finished
Any thoughts
Rick
I'm going experiment with my project . I will see what happens . If this works good , i will build something more permanent . Then post photo's
Don Stauffer posted some pics of his heated drying box a while back, I don't have a link to the thread, but it might be of some help. But I look forward to seeing what you come up with.
Thank you
I send him a e mail
RICK
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/p/161071/1751791.aspx#1751791
Les.61 http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/p/161071/1751791.aspx#1751791
thank you
My small heat pad did not raise the temp about 78 F .
Heat pad too small .
Round 2
My oldest daughter had a snake for long time . She in college now . She gave her snake away .
i still had a under tank heat strip .
I installed that heat strip under storage bog . Temp 92 . almost to hot on the bottom , 82 on top.
The temp probe that shuts on/off heat is about 1 in. from bottom .
i also placed some copper tubing 1/4 in . to help on heating
here a basic picture .
Maybe later , I like to build something like Don's ,but with out the light bulb for heat source .
I am a sheet metal worker by trade . I have access to what I need , Just need to see what works .
Also i don't need anything very big . I like to keep it about 2 ft x 2 ft or so .
The temp can't read , it say 92 f .i turned down to 85
Here is a pic of my drying box. The actual chamber that holds the model or parts is one of those plastic storage containers we take our models to shows in.
Inside of the lower chamber, made from particle board, is a lamp socket and a 60W incandescent bulb. I put a lamp dimmer/switch on the box because I thought I'd need control to adjust the temperature, but it runs at a fine temperature of 105F wide open, so If I built another I would replace the dimmer with a plain switch. There are holes drilled in the top of the particle board box to allow air to flow up into the upper chamber. All holes, btw, are covered with those cloth filters that you use inside of hot air registers to keep dust out. Most of the top of the storage chamber is cut away, except for the flanges, to allow the airflow from the lower chamber. And, a hole is cut in the bottom of the storage box (now the top, since it is upside down), with a filter taped over it. All the holes allow natural convection of the heated air through the system to help dry the paint. It works great and was cheap. It will dry enamel flats in an hour or two, gloss in 6 to 12 hours, depending on thickness of coat. That is my homemade spray booth to the left of the drying box.
Thanks for posting that again Don. I really nee to make one of these. I mainly wanted something to keep the dust away while leaving kits to dry, but if I can speed up drying time as well, that's a bonus.
I like that ideal with the dimmer .
If you use a more powerful bulb, say a 75 watt, the dimmer would be okay. With a 60W a dimmer isn't needed- it runs wide open. There is a range of optimum temps- too hot and parts or assemblies may warp, not hot enough and the drying time is longer. I lucked out on the 60W, I have never warped a part but the drying time is quite short.
Thank you Don
Thats why I have a thermostat to control heat . I really like your ideal .
Is your light installed on the bottom plate or side plate in the lower area ?
Did you install some kind of internal insulation ?
My dry box . I like to keep it about 2 feet long maybe 16 inches deep ..
Nope, no insulation. Bulb socket (just one of those simple surface mount porcelain things) is screwed to the bottom.
This is a slick idea, gentleman!
I think I need to mock me up some drawings, then make one!
Bruce
On the bench: 1/48 Eduard MiG-21MF
1/35 Takom Merkava Mk.I
hogfanfs This is a slick idea, gentleman! I think I need to mock me up some drawings, then make one!
I Also think it's a nice ideal
HI ;
Being as how my work area is not air conditioned, I do this. I take my wet painted pieces, if they are small enough and put them in a Wal-Mart rotissierie chicken container .Well washed, I might add . I then put them on the highest shelf in the Garage.
I then let them sit there for about a day or two .This works best. Now, the big stuff gets put on top of my shelf unit behind my work area .This puts the model about three foot from the ceiling. You see, except for storage around the area, I only have about twelve square foot to call my own .So space is at a premium. Therefore a heated drying box is out of the question . Now my paint booth is collapsible and The unit hangs from the wall when Not being used. T.B.
Cary
Modelers are indeed a funny lot. Here we go choosing a hobby that demands precision and patience while at the same time giving us the possibility of hours of relaxation. So what do we do? We come up with ways to quicken up the process and then ask others how we can improve on the methods we have come up with and finish even faster! Don't get me wrong. I admit to being a member of the group and at one time had a warped Dragon Tiger I tub that was the victim of my own quick drying attempts. I just think it's all kind of funny in a "warped" sort of way!
But watching paint dry is even more boring than watching grass grow!
LMAO Don .
I paint in a non-air conditioned " shed '...it's rather large. I live in Florida so the heat in there has no problem drying paint . I just cover my newly painted models with a clean cardboard box and forget about em for a few days. I usually pass the drying time prepping my next build ie scraping and sanding those DANG mold lines and flash from every DANGED part...I wish the mfgs would cast cleaner models, cuz I hate days of parts prep.
I think I put more crud on my models in the pre-paint work than the mfg leaves on the parts :-(
I leave fingerprints, glue blobs, and sanding dust all over the thing! Have to clean it up just before painting. I do hit the sprues with a coat of prime before I get very far in build, but still need to clean up all the junk I get on the model afterwards.
You know DON ;
That stuff we do to plastic maybe is somewhat self defeating in a fun way .Did you ever think that maybe the plastic doesn't want to be molested but remain on " A " tree instead being united with a part it doesn't like from " C " tree ? LOL.LOL.LOL.
