I do have to pipe in here :
Okay ,now ,if you spend money for good brushes ,you should try to know in advance what that brush or brushes are meant for .Sable , and in my case some mink and chinchilla brushed were inherited from my late wife .They were ONLY used in OIL paints or OIL based paints .I have some of my own that are almost twenty years old .Now , I do have newer brushes made for water based paints .
You don't know this and few do .Nylon has come so far ,you can get a perfectly smooth paint job with one using acrylics. What most folks don't know is the mfgrs. of these latter brushes use a very cheap form of ferrule that is made of supposedly stainless .Well a low grade anyway .Why? Well when you use it , I am sure you wouldn't want rust in the paint now ,would you?.This is the way they think .
In cleaning Any brush , Don't put it in the bottom of the container ,pressing down on it to help clean the brush,while you twirl it .That is a No-No with any brush ! Gently rinse it alongside to side of the container near the top and keep moving it in the manner like you are trying to paint the inside of the container .When clear liquid ,Water ,or Thinner come out of the brush. You are ready.
Now, gently stroke it on the paper towel you got for this, till no color comes out of it . If it is a round brush of whatever size, you may insert in your mouth and gently ( like you are trying to whistle ) draw it out getting a little fluid on it ,as you do this you will be shaping it . Take your flat brushes and Make sure the flat side of the ferrule matches the bristles and run between wetted fingers making sure you don't draw them together at the end of the bristle .You want them to spread the distance they are supposed to be .Let them dry Bristles up in a pen and pencil stand you can get at any office department or store . Good luck . T.B.
