Hi ;
Everyone has given you pretty sound advice .What I would do is this .See if you can feel it with a light pass of a fingernail .If so then do this . Can you remove the window or window unit from the model without damaging it ? If so then sand it WET with 800Grit to get it smooth then graduate to 2000 grit .
After you've done that then use NOVUS polish and then the NOVUS protective coat afterwards .Or just polish it with ToothPaste NOT gel , and then dip it in Future .
