Model Storage - Keeping them In good Shape
    December 2013
Posted by CodyJ on Wednesday, December 17, 2014 7:29 PM
Hello, I have a number of sealed vintage kits from the 60's & 70"s.  Some worth a good amount.  I have ran out of room in my closet and kinda might have filled the spare room closet too.  Embarrassed
Question:  Can you store models in a closed garage and will that keep them safe from boxes warping, rumpling and damage?  I'm in Oregon.  The Garage is Dry but it rains outside all the time.  Humidity can be low to mid range.  Temps go between 30's to mid 80's inside the garage every year.
Thanks! :)
    January 2014
Posted by jelliott523 on Wednesday, December 17, 2014 7:35 PM
I know that I have a bunch of old models in boxes in my garage.  I'm in SW Idaho, and it stays pretty dry year round and the temp range is from the teens in the winter to low 100's in the Summer months.  They collect a bit of dust but are otherwise in pretty good shape.  Maybe if you stored them in plastic totes in the garage that would help.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, December 17, 2014 7:59 PM
+1 on plastic totes. It may help keep the decals from yellowing further. Maybe put towel atop of them to cover them as well before sealing the tote. I know that sounds kinda extreme but hey, anything to protect it more.
    November 2013
Posted by elass0wyp0 on Friday, December 19, 2014 7:56 AM
What about adding those crystal pouches you get in electronics from china.  The furniture stores get large pillows of the stuff in cabinets, see if you can get some of those and make your own smaller pouches with panty hose.  I'm in southern Ontario so we get those things in everything, not so sure about the drier areas.
I'd love to see these closets, you got any pictures you can share?  :)
    February 2014
Posted by CN Spots on Friday, December 19, 2014 1:05 PM
Ditto on the totes and moisture absorbent. They make it in little plastic buckets with holes in the lid too.  I keep one in my old Ford truck.  It would help prevent condensation forming during severe temperature shifts which would wreck your decals and moisten the chipboard boxes that most kits are packaged in. If mold forms on your boxes in a dark container, they're toast.
Also,  photograph the contents of a long storage tote and tape the photo on the side of the box to show what's inside.  Way easier than popping the top and digging through it.
    February 2007
Posted by mitsdude on Saturday, December 20, 2014 12:29 AM
I would also suggest storing them on their sides or ends. Stacking can cause the lids or bottoms to curve inward.
Ditto on the absorbant. Even if the tote is air tight there will be moisture in the air trapped inside and in the cardboard itself. Temperature extremes will cause absorption and condensation inside the sealed tote.
    March 2008
Posted by WigWag Workshop on Sunday, December 21, 2014 4:03 PM
Another thing that I would do, is keep the more valuable ones inside in the closet, and store the other ones has suggested in the garage.
    November 2008
Posted by plasticjunkie on Saturday, December 27, 2014 12:59 AM
Cody
I have kits going back to 1980 and they have been stored in the garage all this time and they are fine. I just recently brought them into my newly expanded man cave cause its easier to access. The only place they may get damaged/warped is in the attic, specially during the summer. That is one place I would not store plastic models just in case.
 GIFMaker.org_jy_Ayj_O
