AB compressor
    March 2010
AB compressor
Posted by Bocks Suv on Monday, December 22, 2014 11:21 AM
I got a used compressor that may have issues. When I turn it on and start to paint, it's constantly  cycling on and off, like 2 seconds on, then 2 off. Drives me a little nuts. The when I stop painting, it's quiet. This doesnt sound normal; is there a leak or is my pressure too high or too low, or am I using the main pressure valve instead of the AM one I installed with an attached gauge?
Also, separate issue, should I get a fine line by limiting the needle or cutting way back on the air pressure?
fox
    January 2007
Posted by fox on Monday, December 22, 2014 11:51 AM
Sorry I can't help you with your problem but if you post this question in the Painting and Airbrushing Section you will probably get the help you're looking for.  Good luck.
Jim Captain
 Main WIP:
