Mr. hobbys - Mr.color aircraft sets
    June 2010
Posted by 5-high on Saturday, January 17, 2015 4:13 PM
hi, everyone        i,m trying out some new paints for my old revell 1/32 spitfire . and im thinking of trying out Mr,hobby paints that i bot back a few years ago . Mr.color aircraft sets ..one is the u.s navy colors ,,,and the secoud one is the british camo # 1 set ,,, and the third interior aircraft set . has anyone used them ..and whats ur thoughts are about this line of paints ?. i,ll be airbrushing the interior with there # (364) -bs283 aircraft grey green . i opened it up for mixing ..and it smeld like acetone ..i,m not sure cuzz its my first time using this brand . i thought acetone is hot to plastic ,,not sure ...Confused and i,m not sure how to mix with there 110 thinner . also how do.es it go down ,, how do,es it dry ...matt or gloss ??
fox
    January 2007
Posted by fox on Sunday, January 18, 2015 1:43 PM
Hi 5-high,  I'm sorry I can't help you with your problem, but, if you go to the "Painting and Airbrushing" section and ask the same question I'm sure that someone will be able to help you.  It might take a little while as things are sometimes a little slow on weekends.  Hope that this helps.  Good Luck.
I'm strictly a Vallejo Model air acrylics and Model Masters and Humbrol Enamels for details.
Jim Captain
 Main WIP:
