How to break a windshield?
    July 2008
Posted by castelnuovo on Tuesday, February 10, 2015 11:54 PM
I am building Tamiya's 1;35 British utility car from WW2. It will be my fist attempt to make a nice rusty wreck. Now, a wreck is not a real wreck IMO, if there is no broken windshield and door windows. The question is, how to break them so that they don't look like I have broken them. I'd like to put few bullet holes or shrapnel holes, maybe damage from a big blunt object...
I am not sure in what context was the vehicle wracked, it is was just abandoned long time ago.
While at it, it comes with a rigid plastic tarp, which is optional. Any tips what would a tarp left on a vehicle look like if it was left exposed to rain, wind, sun for a loooong time?
Many thanks...
    August 2005
Posted by Phil_H on Wednesday, February 11, 2015 12:33 AM
Not sure how you would represent broken glass/windows but remember to take scale thickness into account.
    November 2014
Posted by BLACKSMITHN on Wednesday, February 11, 2015 6:11 AM
Well, for a bullet hole, I'd just drill the appropriate sized hole and then, using a sharp implement, etch around the hole from the hole out in an uneven star shape. For a broken window, just break the plastic with a needle nose plier and glue some of the shards back in place of the whole pane. Remember that there'd be shattered "glass" debris on the side away from the impact (in other words, if the hit came from outside the vehicle, the debris would be inside, and vice versa). Regarding a weatherworn tarp, it would be sun faded and frayed, often with holes that weather, insects, animals, and time-- or some combination thereof-- might have caused. Depending on how much time has passed, it might well be more holes than cloth!
    June 2012
Posted by Compressorman on Wednesday, February 11, 2015 7:59 AM
I have no idea but one would need to know whether or not that vehicle had laminated glass on the windshield.
Chris
    November 2014
Posted by BLACKSMITHN on Wednesday, February 11, 2015 9:27 AM
If you go here: www.perthmilitarymodelling.com/.../aa_k156r2.htm
There is a good picture of a 1/35 model of the cab of an Austin utility vehicle with the windows broken out. That might help give you some ideas.
    August 2008
Posted by tankerbuilder on Wednesday, February 11, 2015 11:26 AM
Hi;
    I have found that if you have .010 or thinner Styrene sheet you can break it just fine .For bullet holes just hit it with a punch .The resulting hole will look alright after some X-Acto knife cracks .
   Now for a shattered windshield just enlarge a punched hole raggedly with the same blade . Then add cracks where you need them . For Tarps I use Brawny brand paper towels , after taking the towel apart and soaking the one ply in diluted white glue and draping it over the frames .
    If you don't have frames you can make them out of brass rod a little smaller than the ribs and then gently hammer it flat , bend to shape and mount temporarily . Drape the towel and let dry . Rip and weather it with a blade and scissors .Tanker - Builder       P.S. Many vehicles had a very poor glass laminate , if at all .
    April 2014
Posted by IamRaider on Thursday, February 12, 2015 3:09 PM
I've seen decals to represent cracks and bullet-holes in glass before. Not sure where I've seen them though.
    November 2014
Posted by BLACKSMITHN on Thursday, February 12, 2015 4:16 PM
    July 2008
Posted by castelnuovo on Thursday, February 12, 2015 9:43 PM
Thank you gentlemen. Blacksmithn, thanks for the link to that model, that is exactly what I was looking for.
Cheers...
    November 2014
Posted by BLACKSMITHN on Friday, February 13, 2015 7:33 AM
Glad I could be of help. You'll have to let us see how the finished model turns out!
    June 2010
Posted by OctaneOrange on Monday, February 16, 2015 8:38 PM
i suggest either
1. replace the windscreen with clear acetate sheet and cut the center of it out, leaving just the jagged edges.
2. scratches on the rather thick kit part will look like it's cracked, which is what i did for Eleanor Mustang. these were just done with a fresh-sharp hobby blade.
3. leave the glass out all together and just use salt to represent the remains of the glass (only works for tempered glass).
    March 2005
Posted by TarnShip on Wednesday, February 18, 2015 1:33 PM
How about a plastic sheet of "Shattered/Cracked Glass"?
www.megahobby.com/laser-cutclearplasticshatteredcrackedglass1-35dioramasplus.aspx
hope this helps
Rex
almost gone
Posted by Texgunner on Wednesday, February 18, 2015 1:39 PM
"How to break a windshield?"    Well, a painter I used to work with had his broken when his "ol' lady" threw a starter through it![:D]
"All you mugs need to get busy building, and post pics!"
    June 2004
Posted by seasick on Sunday, February 22, 2015 11:38 PM
Can you make a believable decal?
Chasing the ultimate build.
    February 2015
Posted by Tdavid on Saturday, February 28, 2015 11:12 AM
I haven't done it in years, but when I was younger, I liked to damage my models a little. (A car that was in a glancing collision for example). I would actually use a nail, or large push-pin. Heated up, then spiderweb windshields etc... With it. I wasn't as picky then though!
