Glue (Part whatever)
    April 2013
Posted by Digital_Cowboy on Monday, February 23, 2015 10:37 AM
          We all know (by now I hope) that there are MANY different types of glues out on the market.  And that each glue has its use on our bench.  Such as:
  • epoxy
  • white glue
  • rubber cement
  • plastic cement/glue
  • CA
  • etc.
          And right now in my toolbox I have the following glues:
  • Elmer’s Glue-All
  • A “no name” (I can’t remember the brand) two-part epoxy
  • Testors liquid plastic cement
  • Testors “blue tube” plastic cement (5 tubes)
  • Model Master/Testors Clear Parts Cement & Window Maker
  • Duro Super Glue
          For most of the types of cements/glues there a “zillon” different manufacturers.  Using plastic cement/glue as an example there is Testors (which probably most of us grew up using), there is Tamiya as just two examples.  And as with CA/super glues there is thick and thin versions.
          Other then personal choice when would/do most people use the different types of cements/glues?  I know that white glue/Model Master Clear Parts Cement & Window Maker are preferred for mounting windows and other clear parts to avoid crazing.  And that the “thick” glues or cements can be used to help fill in the seams.  But aside from that, as I said, I guess it comes down to personal choice as to what cement/glue one wishes to use.
Digital Cowboy
Live Long and Prosper
On the Bench: '64 Ford Fairlane; '09 Corvette Coupe
    April 2009
Posted by Cadet Chuck on Monday, February 23, 2015 12:51 PM
I use many different glues on each model, depending on which best suits the joint at hand.  For instance, I use Tamiya thin solvent for binding plastic to plastic, and CA for sticking metal PE parts to plastic, etc.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, February 23, 2015 12:57 PM
Glues I use:
Tube glue - used on rare occasions
Tamiya liquid glue
CA
Elmer's glue (for canopies)
Super glue (for PE)
Posted by Texgunner on Monday, February 23, 2015 1:11 PM
No one so far has mentioned Faller Expert cement.  The "needle" applicator helps a lot.  I use that quite a bit and it works really well for me.
"All you mugs need to get busy building, and post pics!"
Posted by Tojo72 on Monday, February 23, 2015 1:30 PM
My glue of choice is Tamiya Extra Thin,I also use a CA type glue and a white glue for canopies.
    March 2005
Posted by TarnShip on Monday, February 23, 2015 1:52 PM
Three really handy Glues that often get left out of the lists are the Watch Crystal cement for attaching canopies, (available as GS Hypo Cement), and Gator's Grip water based superglue, again for attaching canopies and underwing stores.
Gator's Grip is no relation to any of the Gator/Gorilla Glues available at the home improvement stores or Wal Mart, it is a designed for models water based glue, designed and sold by a modeler.
Aleene's Tacky Glues are also very useful to have around. I used to buy them direct from the Aleene's Dress shop in Wisconsin Rapids, but, since moving to Tennessee, I just buy those at Wal Mart now. There are many more choices than just the old "brown bottle" glue from Aleene's.
Rex
Gator's site  www.gatorsmask.com/gatorglueorder1.html
GS Hypo at Starfighter's  www.starfighter-decals.com/gs-hypo-cement.html
Aleene's home site   www.ilovetocreate.com/Tacky
almost gone
    April 2013
Posted by Digital_Cowboy on Monday, February 23, 2015 2:24 PM
Thank you everyone for your input.  As I said in my OP, it comes down to two factors:
a)  Personal choice
b)  And the job at hand
Digital Cowboy
    March 2005
Posted by Devil Dawg on Monday, February 23, 2015 10:47 PM
Glue?? You mean I'm supposed to use glue?? I've been using tape all these years!!!  Propeller
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    August 2005
Posted by Phil_H on Monday, February 23, 2015 11:10 PM
Texgunner
I love that stuff. Unfortunately it's been unavailable here in Australia for many years. These days I primarily use Tamiya cement, both the extra thin and regular liquid cements.
    February 2007
Posted by mitsdude on Tuesday, February 24, 2015 12:19 AM
Don't forget hot glue. Good for tacking down wires (for lighting) or reinforcement of an internal part.
    April 2013
Posted by Digital_Cowboy on Tuesday, February 24, 2015 8:52 AM
DD,
    Ya mean I was supposed to be using tape instead of glue?  Who knew. ;-)
Digital Cowboy
Posted by Don Stauffer on Tuesday, February 24, 2015 8:57 AM
I also use white glue and derivatives for canopies, since a canopy is easy to glue back on if it breaks loose.  However., for windows that fit inside fuselage on transports and bombers I go with epoxies. I have had some problems lately with some epoxies not being as strong as ones I used in past.
I ordinarily use gel CA rather than the thin stuff, for two reasons.  First, I like the slower setting.  I can always apply accelerator if I need a quicker set, and the gel is somewhat gap filling.  I find the thin works best if part surfaces match extremely well.
    April 2013
Posted by Digital_Cowboy on Tuesday, February 24, 2015 9:13 AM
Don,
    A good question that you elude to in your post.  When should one use capilary action and when should one "paint" the glue on both pieces to be joined?
Digital Cowboy
    August 2014
Posted by Weird-Oh on Saturday, February 28, 2015 10:55 PM
I mostly use Zap-A-Gap for just about everything, but I build a lot of resin kits. I clearly remember when the whole anti-glue-sniffing movement began and Testors started putting out this citrus-based stuff that wasn't worth a rat's patoot. I was showing a friend a 2001 Orion model I'd built using the stuff when he accidentally dropped it about a foot onto concrete, and it underwent rapid unplanned self-disassembly, as Elon Musk would say. Literally went back to its component parts. I'm glad those days are gone.
    April 2013
Posted by Digital_Cowboy on Sunday, March 1, 2015 8:13 AM
Weird-Oh,
    I think I remember that "lovely" glue.  They still produce a non-toxic tube version of their cement.  It's in a blue tube.  I don't know how strong it is, as I've never used it.
    But, yes, I've gotta say that I agree with you there.
Digital Cowboy
    January 2013
Posted by Souda99 on Monday, March 2, 2015 9:08 PM
Ok I know this is most likely goung to make me sound like an idiot but hey here it goes. I currently use the liquid testors glue that has the brush applicator and then some other glue that my fiance bought me about a year ago that comes in a glass bottle and has a needle like draw tube for a squeez type applicator. But what glue do I use for resin kits and what is CA?
    January 2014
Posted by jelliott523 on Tuesday, March 3, 2015 12:44 PM
CA is cyanoacrylate...or Superglue for the everyday term.  There are many different manufacturers and it comes in super thin, thin, medium, thick and just about any other viscosity that you can imagine.  I'm sure that you've seen it in its various forms and packages.
    August 2014
Posted by Weird-Oh on Tuesday, March 3, 2015 6:26 PM
Cyanoacrylate is what I use for resin kits, but with most of them, the assembly is the easy part, at least with figure kits. The skill comes in with puttying, sanding and painting. I use Aves Apoxie Sculpt for putty, and it's amazing stuff. Thins with water, so I can smooth a puttied joint before it sets to the point that it hardly needs any sanding. I even use the stuff to fix broken items around the house, because it sets up like porcelain.
