Sandpaper
    January 2013
Sandpaper
Posted by Souda99 on Friday, March 6, 2015 4:51 PM
Can some one tell me what the most common and widely used grits of sandpaper there are. Looking to make a run to Lowes to stock up. I currently have a little sanding stick that wad my grandfathers and only like 2 grits of sanding belts.
    May 2003
Posted by qmiester on Friday, March 6, 2015 5:00 PM
I would recommend the wet/dry (black) sandpaper used wet.   The Grits that I use the most are 360, 400.600 and 800.  I also keep a sheet or two of 1000, 1500 and 2000 on hand.  I would make a suggestion in that you might find a wider range of grits in an auto supply store (especially if that store provides automotive paints and supplies).  HTH
Quincy
    January 2013
Posted by BlackSheepTwoOneFour on Friday, March 6, 2015 5:21 PM
Get some sanding sticks too. They help getting in tight spots.
    November 2003
Posted by mississippivol on Friday, March 6, 2015 6:05 PM
I use 400-2000 grit for most work. I get mine in the automotive section of Walmart. For canopies or paint polishing, I use the 3200-12000 grits, Hobby Lobby sells those, or you can get them online.
Posted by Don Stauffer on Saturday, March 7, 2015 9:53 AM
I keep few sheets of the coarser stuff- I use needle files for that. I keep on hand 400, 600 and 1000.
    March 2005
Posted by Devil Dawg on Monday, March 9, 2015 6:31 PM
Ditto to everything above. Also, if you buy the large sheets of sandpaper (regardless of grit), cut them into usable strips, and label the back of each strip as to their grit. Makes them easier to store, and, because you've already cut them to strips, makes 'em a lot easier to grab and use instantly when you need them.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
Posted by Texgunner on Monday, March 9, 2015 7:22 PM
Devil Dawg
+1
Dawg, that what I do too, well, the labeling part anyway.  Every time I cut  a piece from a sheet, I write the grit number on back in pencil.    I keep a small pile of used pieces on the work table so there's always some sandpaper handy for those little needs that will crop up.  Great advice DD!Yes
Gary
"All you mugs need to get busy building, and post pics!"
    January 2006
Posted by dirkpitt77 on Monday, March 9, 2015 8:22 PM
Alpha Abrasives offers a variety pack or two with multiple grits in each. I got mine at Hobby Lobby with a 40% coupon.
Although I"ll use 320 or 600 grit from the hardware store for general sanding work, I use the Alpha Abrasives set on canopies.
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    February 2011
Posted by Raualduke on Monday, March 9, 2015 10:20 PM
Everything posted above is great advice. Only thing I wanted to add is that it's not too tough to make your own sanding sticks. You already have the sandpaper,so just some popsicle sticks carved or sanded to shape  and a can of 3m spray adhesive  and your good to go.  Mike
    August 2014
Posted by Weird-Oh on Tuesday, March 10, 2015 4:51 PM
Hadn't thought of popsicle sticks. I bought a big wad of mixing sticks for casting that are closer in size to tongue depressors; I'll bet those would work too.
    March 2005
Posted by Devil Dawg on Saturday, March 14, 2015 11:24 AM
Texgunner
Devil Dawg
+1
Gary
***sniff*** Why, thanks, Gary. That there's the best thing any modeler has ever said to me. ***sniff***
Propeller Stick out tongue
Seriously, though, glad you liked it. It's one of the reasons I love this forum - all the things you can learn from everyone else. I can't even count the new techniques that I've learned just by perusing the threads here. And it's all free!!!!!! Woo Hoo!!
Gary Mason
Devil Dawg
