Testors finish
    March 2015
Testors finish
Posted by Rotorhead40 on Sunday, March 8, 2015 7:43 AM
What is the best way to remove flat finish spray from windows?
Posted by Texgunner on Sunday, March 8, 2015 10:05 AM
New windows I'm afraid.Sad
"All you mugs need to get busy building, and post pics!"
    May 2003
Posted by qmiester on Sunday, March 8, 2015 10:30 AM
I'm making the assumption (and yes I understand what "assume" means) the canopy is firmly attached to the model,  In that case, I would mask around the canopy and then get some superfine automotive rubbing compound, a damp rag and proceed to rub the overspray off the canopy.  Finish the job by carefully repainting the frame of the canopy and then removing the tape.  Just a thought
Quincy
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, March 8, 2015 10:50 AM
That all depends. is it a car model or aircraft model? Is it a canopy? If so, pop it off your kit and try and clean it with thinner and polish again. Or order a new canopy from the manufacturer.
    November 2008
Posted by plasticjunkie on Tuesday, March 10, 2015 10:09 PM
If the overspray is fresh and it's flat acrylic, then use some Windex to remove it. If it's lacquer you will need a new replacement as the lacquer thinner is too strong and will damage the clear part. As a last resort try applying Future to see if it neutralizes the flat finish.
 GIFMaker.org_jy_Ayj_O
