colin window cleaner as a thinner
    November 2014
Posted by sherbir on Wednesday, March 11, 2015 2:28 AM
I don't have windex available in my country. Colin window cleaner is the closest I can get to Windex. Can I use that as a thinner for acrylic paint on my model?
Regards,
Sherbir
    March 2014
Posted by BarrettDuke on Wednesday, March 11, 2015 5:00 AM
Looks to me like the main ingredient in Colin is vinegar. Windex is a completely different formula with ammonia. So, I doubt you would get the same effects. In fact, I don't know how vinegar would react with acrylic. I doubt I'd try that unless I was desperate.
fox
    January 2007
Posted by fox on Wednesday, March 11, 2015 11:41 AM
Ditto on what BD said above.  If you know anyone that uses any kind of window cleaner with ammonia, borrow a small amount and try it on an old scrap of plastic. That way, nothing ventured and nothing lost except a little time and a couple drops of paint. Try a small amount, paint the scrap, and let it dry overnight to see if anything happens in the drying process. Be sure to let us know the results as someone else might have the same question.
Hope that this helps.
Jim Captain
 Main WIP:
    September 2006
Posted by the Baron on Wednesday, March 11, 2015 11:45 AM
Test it on a scrap with the paint that you want to thin.
The only vinegar I have ever used on my bench, is distilled white vinegar, as a cheap substitute for decal setting solutions.  I have never tried using it as a paint thinner.  For acrylics, I use either water or isopropyl.  So I'm curious, too, to know how it comes out for you.
    March 2010
Posted by Nathan T on Wednesday, March 11, 2015 12:12 PM
Stay away from using ammonia in your airbrush. Its caustic to the brass and other plating.
    September 2012
Posted by GMorrison on Wednesday, March 11, 2015 12:17 PM
Ammonia is nasty stuff.
    November 2014
Posted by sherbir on Thursday, April 9, 2015 3:36 PM
Colin failed. Broke the paint away. I used isopropyl alcohol instead. Worked like a charm.
Regards,
Sherbir
Posted by Don Stauffer on Saturday, April 11, 2015 9:12 AM
Window cleaners with isopropyl alcohol will work.  But iso is usually also available in drug stores or other stores that sell medical products.
    September 2012
Posted by GMorrison on Saturday, April 11, 2015 1:58 PM
My thinner of choice for acrylics. Either 70% or 90% work fine
