Peeling decals on my beloved P51 :(
    May 2015
Posted by Funks on Monday, May 11, 2015 2:50 AM
Can anyone please help!?
I completed my Tamiya P51D 1/32 scale about 3 years ago but now some of the fine deatial decals are peeling off. None of my other kits are, Im guessing its because I used the tamiya silver spray out of a can, not sure. All my others are matt finished from my airbrush.
What would be the best way save these decals or get new ones for the type of P51. Its one the Blue nosed bastards from the 352nd USAF, Tamiya P 51 D Mustang 1/32 scale - Lt Col JC Meyers P51.
Please see this, it may help and many thanks guys!
[youtube]UpuOlB6U8WA[/youtube]
    August 2005
Posted by Phil_H on Monday, May 11, 2015 8:22 AM
It might be a case of over-soaking the decals when they were applied, causing loss of the glue.
You could try a very thin solution of white glue & water and see if it pulls them down again.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, May 11, 2015 9:07 AM
Type of paint used - bottle or rattle can is not the cause. Sounds like a case of not sealing the decals with a coat of clear coat 3 years ago.
    November 2008
Posted by PaintsWithBrush on Monday, May 11, 2015 10:32 AM
I never considered the soak time of the decal. I have some builds that are having decal lift problems, but they are flat paint with no clear/dullcoat covering.
A 100% rider on a 70% bike will always defeat a 70% rider on a 100% bike. (Kenny Roberts)
    May 2015
Posted by Funks on Monday, May 11, 2015 3:16 PM
Thanks for the replies. Ive never sealed decals on any of my other builds and not one has lifting problems. this is P51 anyway, you can see Im going to have a headache getting these types of replacements. Anyone know where I could get some just in case the fix goes south and breaks them up?
www.youtube.com/watch
    January 2013
Posted by BlackSheepTwoOneFour on Monday, May 11, 2015 7:42 PM
Decals don't adhere to flat paint well. That's why it's important to spray a coat of gloss clear coat or even Future. Once the decals are set and dried, you can spray a coat of flat clear coat on top of it.
    November 2008
Posted by plasticjunkie on Monday, May 11, 2015 7:59 PM
You can try to save the decals by using Solvaset or Microsol  to settle the decals down. Wait a day or two to make certain the solution has evaporated then apply a clear coat like Future to seal the decals and lock them down even more. If you want to kill the gloss then shoot some clear semi gloss.
 GIFMaker.org_jy_Ayj_O
