Contact for workbench surface.
Posted by Don Stauffer on Saturday, August 8, 2015 9:36 AM
We have had a lot of prior discussions on workbenches, and how to keep the surface clean.  My workbench top is a sheet of particle board, unfinished, with contact paper ( or generic equivalent) over it.  I replaced the contact paper yesterday, and thought I would show how nice it looks. I replace it about every two or three model projects.  No matter what the glue/paint, or whatever, pulling the old sheet off and replacing it fixes things. I use one of those green foam cutting mats to reduce the slicing of the contact paper.
Contact covered workbench.
    January 2009
Posted by fermis on Saturday, August 8, 2015 10:41 AM
I still swear by having a sheet of 1/4" glass as a work surface.
Nice to cut on..I keep a cutting mat under it...I know, totally defeats the purpose of a CUTTING mat!..it pretty much only gets used for its grid(lining parts up nice and square)
A few swipes with a razor blades cleans off any mess!
The glass is framed in, on the bench...I put a couple tape tabs at the top, so I can left it out the clean up under it (little plastic shavings find their way in there somehow!)
    December 2014
Posted by SChambers on Saturday, August 8, 2015 7:01 PM
I also use glass,works great.
    July 2014
Posted by Bakster on Saturday, August 8, 2015 8:07 PM
Seems like a good idea, Don.
    July 2015
Posted by CheesyMeatBurrito on Sunday, August 9, 2015 1:13 AM
ikea desk with a cutting matt you all and your fancy tools. I wipe it down with alcohol if need be.
Posted by Texgunner on Sunday, August 9, 2015 8:59 AM
CheesyMeatBurrito
Drinking?Tongue Tied
"All you mugs need to get busy building, and post pics!"
    July 2015
Posted by CheesyMeatBurrito on Sunday, August 9, 2015 2:52 PM
Rubbing. Not a drinker. :)
Posted by Texgunner on Sunday, August 9, 2015 3:04 PM
Who knew?!?!Big Smile
    February 2007
Posted by mitsdude on Monday, August 10, 2015 12:25 AM
I too use a sheet of glass from a discarded coffee table. Its tempered and beveled around the edges.
Makes a great paint pallette. Will also hold a dab of glue.
An occasional trip out to the water hose and a razor blade makes it as good as new. I placed some of those round self stick felt pads on the corners. I can then slide the instructions, a photo, a grid, colored paper, etc underneath.
Also works great when soldering. Unfazed by the iron or drips of solder!
    April 2009
Posted by Cadet Chuck on Monday, August 10, 2015 11:58 AM
I use a foam-backed piece of poster board from the frame dept at HL, and staple it to the particle board work bench top.  I change it every few years when I can no longer stand the filth.....
