Don -
I fully agree with your points, the kits are becoming much better due to the advancements in manufacturing. I've tried a couple of the new Airfix kits in 1:72, Tiger Moth and Typhoon, very nice to work with and great details. Many of the parts are quite small and delicate, more care is needed, but still the end product is nicer.
The Revell Germany B-17G is really of fine quality, overall perfectly kitted, the parts fit is terrific. The only difficulty was the belly turret, the support struts from the upper portion to the turret mounts are finely done, but EASILY broken even with careful handling. Solved the problem with fine Evergreen strip stock, heated to bend around the attach points and cemented in place like a weld bead. It cannot be seen as it's deep in the fuselage, should have thought about it earlier.
The saw mentioned is great, as are the Xuron's. Many times I have found the little flat bladed stamp handling tweezers to be helpful, particularly for decals. The tweezers with tiny cups at the ends are helpful for holding small bits, I think they might be used by folks that do jewelry and beading.
What I'm especially appreciating is the finer external details, such as panel lines and air inlets. Thankfully the golf ball rivets are gone. Restoring panel lines after sanding is a bit more demanding, with my tired old eyes and shaky fingers, but certainly do-able, just takes more time, I have lot's of that.
You said it right, going backward isn't the right direction. Good post subject, thanks.
Patrick
