Washing without changing color of flat surface?
    August 2015
Posted by Dolphin24 on Sunday, October 11, 2015 4:56 PM
So I am running into problems with my weathering for a desert tank. But generally speaking I have had this issue with any project that is painted a lighter shade.my umber wash gives a great effect on hard edges but also darkens the entire body. If I just wash the edges it creates a unnatural break in color which doesn't look good. My work around was doing the entire piece in umber wash then heavly dry brushing the desert yellow back on. This actually turned out great and will use it again in the future.. but my question is how do you do a wash that will change colors around hard edges and parts you want but not effect the color of the flat, large surfaces that you want to keep the original color. Diluting the wash doesn't give me the effect I need around the edges but works better for flat areas
Any tips would be great.
Thanks guys
    October 2010
Posted by hypertex on Tuesday, October 13, 2015 7:50 AM
What are you using for your washes? Water-based or oil-based washes?
I use artist oils thinned with odorless thinner for my washes. What I do is load a round brush with the wash and touch the tip to the recessess and raised details. Capillary action draws the wash around where I need it to go. I then go back with a brush damp with the oderless spirit and clean up the spots where I touched the brush to the model, as there is usually excess paint at the touch point.
You could do something similar with your hard edges. Just go back with a damp brush and clean up your hard edges. Also, you can pre-wet the flat areas with a bit of odorless spirit before you apply the wash. Don't flood the model with spirit, just make the surface wet. This makes it easier to clean up the hard edges.
    August 2015
Posted by Dolphin24 on Tuesday, October 13, 2015 7:58 AM
Great answer! I use water based... Vallejo washes. If I mix my own then it is tamiya paint and x20a thinner. But your prewetting suggestion was a great idea. Thanks so much for the reply.
Posted by Don Stauffer on Tuesday, October 13, 2015 8:40 AM
An advantage of dry-brushing rather than washes (other than pin washes) is that dry brushing gives you great control over exactly where the color changes occur.  I use washes where there is a lot of detail distributed over and area where washes could nestle down and affect colors, but for flat panels with little detail, I prefer dry brushing to alter only areas of panel.  Or, pre-shading also works for those areas.
    November 2008
Posted by plasticjunkie on Tuesday, October 13, 2015 10:01 AM
If I'm understanding what you are trying to accomplish is to have the wash settle on the sharp details such as corners, louvers, bolts, panel or hatch lines? If so then you have to gloss up the entire model so the wash just settles on those areas and is not absorbed by the entire surface area as it will happen over flat paint that acts as a sponge.
I rather make my own washes out of turp and artist oil paints which flow much better than acrylic washes.
 GIFMaker.org_jy_Ayj_O
    September 2012
Posted by GMorrison on Tuesday, October 13, 2015 11:11 AM
I use Turpenoid and oils very diluted. You can also get good at blotting off the wash from the flat areas with tissue or paper towel. That creates an effect of its own.
