Will a wash using Artist Oils be okay over a coat of Enamel Gloss Coat?
    February 2015
Posted by panzer948 on Wednesday, October 14, 2015 12:58 PM
Hi,
Trying to wrap up my cockpit of my 1/32 JU88-A1 (with many PE pre-painted parts).  Base painting is done so it's time to move onto the weathering stage.  I painted the interior base coat using Tamiya Arcylics but have some of the details, including the seats and metallic area with Model Master Enamels.  I know it is better to seal the base paints using a glosscoat first before adding a wash to darken the recess areas (and later drybrusing). I read arcylic clear coat to protect from artist oils thinned with mineral spirits is best. However, upon inventory I noticed I only have Model Masters Enamel Gloss Coat.  I am pretty sure there is no problem putting this over both my acrylic and enamel base paints but I am worried that my oil paints that I plan on thinning with Mineral Spirits could damage the clear coat?  Wanted to put it on tonight and didn't want to add a trip to the store to slow me down.  So will my MM Enamel Gloss Coast be okay for this?
On the bench: Revell 1/32nd Junkers JU-88 A1
    September 2012
Posted by GMorrison on Wednesday, October 14, 2015 3:53 PM
The only way to know is to try a test.I'm skeptical.
next time you go to the supermarket buy a bottle of Future floor polish. It'll last quite a while, stores well and airbrushed ok.
Posted by Bish on Wednesday, October 14, 2015 3:56 PM
I fear this will not end well if you do. I have had a couple of occasions where I didn't properly apply my future coat to protect enamels paints before adding the wash. It has the same effect as paint stripper.
    February 2015
Posted by panzer948 on Wednesday, October 14, 2015 4:42 PM
Yes, to be honest, I am not sold on using Future as I have heard a mixed bag of results with it. It is even hard to find in stores (I have been looking for it everywhere).  Also, I would rather not try to airbrush it as that also seems finicky.  For adding clear coats I am still okay with using a spray can which will keep things simple and quick.
    February 2015
Posted by panzer948 on Wednesday, October 14, 2015 4:46 PM
So if I don't want to use Future would the Tamiya Acrylic Gloss Coat be the safest bet? I know where I can get some locally but it's to far of a drive to do it tonight.... oh well. Maybe I should try my MM Enamel Gloss Coat on a small separate cockpit piece to see how it goes. Say one of the seats!
    April 2006
Posted by waynec on Wednesday, October 14, 2015 4:51 PM
i have oil washed and water washed over Tamiya, MMA, PolyS, and Vallejo/Vallejo Air WITHOUT a barrier with no problems. not even an acrylic semigloss or flat overspray on the paint. i do prime everything prior to painting. the pnly time i had a problem was dulcoat over Tamiya which ran like crazy over the MMA camo. After walking away for a day and learning some new words i was able to turn this into a positive.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    November 2008
Posted by plasticjunkie on Wednesday, October 14, 2015 7:16 PM
A simple answer to your question is NO. If your glosscoat is enamel and you run a solvent type wash it will lift and wrinkle the paint, specially over large areas.
You need a barrier when using a solvent wash over enamels. I would not risk it over lacquers either just in case the milder wash reacts on the lacquer. On cured acrylics you may use an acrylic wash without a barrier as these two do not react the same as solvent types.
I use Future all the time as a barrier on my enamels and it works just fine. It just needs to cure at least for a day or two.
An alternative to future is Alclad Aquagloss which is water based and cures faster than Future.
 GIFMaker.org_jy_Ayj_O
    January 2014
Posted by Silver on Sunday, November 8, 2015 1:34 PM
Artist Oils never dry.They will work.Just handle w/care.
