Flash Trimming Suggestions Needed
    September 2013
Posted by cvsaylr on Tuesday, December 8, 2015 6:05 AM
I need a method (tried and true?) to trim flash and seams from very small or very thin parts such as davits, winches, flag poles, and other ship deck equipment. I use a set of jeweler's files but have no good method of holding the part. I have tried tweezers, tape, and even (?!) fingers but I can't get a good enough grip on the part to effectively trim it. Additionally, I'm really afraid of breaking the part no matter how I hold it, or having it fly out of the tweezers and into the carpet. Can you guys suggest a method whereby I'd at least have a chance of success?
Dave
    August 2005
Posted by Phil_H on Tuesday, December 8, 2015 6:11 AM
Have you tried self-closing tweezers or hemostats?
    September 2013
Posted by cvsaylr on Tuesday, December 8, 2015 8:12 AM
Yes, both. The self closing tweezers don't hold the parts strongly enough (they can still slip out and get eaten by the carpet monster) and the hemostat crushes the part.
Dave
    August 2014
Posted by goldhammer on Tuesday, December 8, 2015 8:36 AM
How about the aligator clip weighted base adjustable "helping hands"  And use some masking tape sticky tape out over the teeth on the clips?
    September 2012
Posted by GMorrison on Tuesday, December 8, 2015 8:42 AM
Yep I depend on the Mark 5 digital clamps. Also, for stuff like seams, I try swiping them off with sanding sticks.
    September 2013
Posted by cvsaylr on Tuesday, December 8, 2015 8:42 AM
I was actually thinking of some masking tape sticky side out on the self closing tweezers. Never tried the alligator clips. Are they available from Micro-Mark?
Dave
    August 2008
Posted by tankerbuilder on Tuesday, December 8, 2015 8:57 AM
Hi Dave ;
    What I do and believe me , I do this a lot . I put the part on Scotch Magic mending tape .Why ? well you can see it and you can clean flash off quite easily . Just take the tape and burnish it down on one half of the part and have that half already cleaned while still on the sprue.
    I have been doing it this way for years now with great results .  T.B.
    August 2014
Posted by goldhammer on Tuesday, December 8, 2015 9:00 AM
Availble from several sources.  I got mine from Radio Shack as a soldering stand.  They are adjustable in all 3 axis.  I use mine mostly as something to hold props, etc when painting.  I know I saw one in MM catalog.  RS version was under 20 bucks, and most come with a magnifying lens as well.
    August 2015
Posted by Cat Daddy on Tuesday, December 8, 2015 10:46 AM
tankerbuilder
Hi Dave ;
I've used tape to hold small parts to good effect also. A blob of blue-tack or poster putty has also served as a holder.
    September 2013
Posted by cvsaylr on Tuesday, December 8, 2015 11:15 AM
I was actually thinking of using the blue tack, but I will try the scotch tape. I tried Tamiya tape on the end of the self closing tweezers but couldn't get the tape to hold too well. Thanks for the suggestions.
Dave
