I use the automotive de-greaser SuperClean. It's not nearly as caustic as oven cleaner, and you can use a batch of it over and over. I first used it, after reading about it on the Agape Modeling forum, for removing the chrome from the plated parts of the Red Baron Hot Rod kit. It removed the chrome in under 2 minutes, leaving the parts squeaky-clean, literally, since it also removed any grease. I use it now to strip paint from styrene, resin and metal. I let the pieces soak for at least 5 minutes, then begin scrubbing gently with an ols toothbrush. The longer you let the piece soak, the more the paint just dissolves into the solution.
You can immerse your model in it, or you can soak paper towel or a rag in it and apply it, though that will take longer.
I use old glass baking dishes, and glass jars, for soaking parts in the liquid.
I also use it now, instead of dishwashing liquid, in the solution I use to clean the sprues of mold release agents before I start assembling a kit. Just a couple of drops.
At about eight bucks a gallon at Walmart, for a product that I can use over and over, it's a bargain. And it also has household uses, uncloging drains, from example, or cleaning up oily or greasy stains on surfaces, cloth.
Hope that helps!
Brad
I have to agree regarding Super Clean-just be sure to use some surgical gloves-Super Clean is very caustic and will dry your hands out very quickly
