Okay to use spraycan MM lacquer based Gloss over an airbursh coat of MM Acrylic Clear Gloss?
    February 2015
Posted by panzer948 on Wednesday, February 10, 2016 8:54 AM
I have my camo scheme finally painted like I like (after a couple of attempts/touchups and am prepping the model for decals.  Yesterday for the first time I used my airbrush to apply Model Master Acrylic Clear Gloss. I am really trying to transition most of my painting to the airbrush as I do feel it gives much better control. Based on what I read, I only added a few drops of their recommend 4096 thinner.  It seemed to spray okay and it does dry super-fast. I added two light coats over a period of an hour.
I checked it this morning and it seems rather spotty in some places.  Not a consistent solid sheen like I thought it would look like.  I still have some Rattle Can Model Master Glosscoat (pretty sure this is lacquer based) that I use to always use.   Tonight I was thinking of just finishing it off with this as I know it "should" give me that nice solid look I recall. Will this be okay to cover over the acrylic based clearcoat?   Thanks for any tips!
On the bench: Revell 1/32nd Junkers JU-88 A1
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, February 10, 2016 9:09 AM
You'll get better luck if you post this in the paint section of the forums.
    February 2015
Posted by panzer948 on Wednesday, February 10, 2016 9:41 AM
Oops sorry. You are probably right.  I did try to edit it but didn't see a place to move it. Maybe the moderators can help.
    September 2012
Posted by GMorrison on Wednesday, February 10, 2016 10:23 AM
I think if it's visibly spotty now, a clear overcoat won't make it any less so.
    February 2015
Posted by panzer948 on Wednesday, February 10, 2016 10:38 AM
Hmm. Okay, so what could cause the spotty areas?  Would a flat coat later even this out more?  Prior to adding the clear coat the finish seemed more uniform. Maybe it brought out areas that received more paint than others or of one particular shade over other areas (I did some post shading using highlights of the original base coat).
    February 2015
Posted by panzer948 on Thursday, February 11, 2016 10:03 AM
Update. I am very disappointed in MM Acrylic Clear Gloss.  Last night I was doing some minor prepping (removing dust) of the model in preparation for adding my rattle can Testors Enamel Clear Gloss and noticed the MM Acrylic Clear Gloss I sprayed 24 hours earlier was actually coming off like fine dust!  Wow. Never seen this happen before in a gloss coat.  After this bad experience it will take a lot of convincing for me to go back to an acrylic sealer using an airbrush.  I just don’t think it is as tough and durable as what I have seen from the enamels/lacquers in a rattle can.  I can’t imagine the acrylic floor polish that seems so popular now being much better. I did spray in my garage which is only heated with an electric heater near my workbench. It was comfortable to me but the temp was still probably around 60 degrees F (or high 50s).  Still can't believe how horrible that finish was.
Luckily spraying the Testors/MM Enamel Gloss Coat last night seemed to correct it.  I put one good coat on and plan on giving it another one tonight.  Although I ran out of product so I plan picking more up today.
Any recommendations on your favorite rattle can clear gloss?  Below is the one I used. I had read somewhere this is really a lacquer based system; or maybe that is another product.  I am hoping that it will still hold up to a wash using enamels.
    March 2015
Posted by Toshi on Thursday, February 11, 2016 10:48 AM
I've used both without any issues, especially when you described that the MM acrylic gloss comes off as a powder.  Hmmm!  I've never seen that.  I also am going to try to use for the first time, Vallejo gloss acrylic.  I'll see how that goes.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    February 2015
Posted by panzer948 on Thursday, February 11, 2016 10:53 AM
Toshi
Toshi
Thanks for the reply. Interesting that you have used both.  Did you feel that the rattle can enamal clear was a lot tougher/thicker/stronger.  Even with my one coat it seems so much more glossy and smooth.  I do hate that I have no control over the spray like I do with an airbrush.  Just will have to be more careful.
    January 2003
Posted by CNicoll on Thursday, February 11, 2016 3:49 PM
Panzer:
Nothing more frustrating than to get to this stage of a build and have these kinds of problems! Sorry to hear of your challenges here.
I've finished four different aircraft in the past few months, and I used MM Clear Acryl on all four for decaling as well as masking with tape, and with clay.  I have never had any issues with peeling or flaking.  Perhaps a humidity issue delaying drying? Or was the undercoat fully dry as well?  I usually try to wait 36 hours or more after a gloss coat before I decal or use mineral spirit based washes.
Or maybe you just got a bad bottle of acryl?  Suggest you try it again on a scrap model and see if it does the same thing.
Very interested to hear the results and good luck.
On the bench:  Academy 1/72 B-17G 'Blue Hen Chick';  1/48 Tamiya Mustang III; Kitty Hawk 1/32 P-39.
Completed:  1/48 Tamiya P-51D Mustang - 'Show Bird', 1/32 Dragon P-51D  Flying Tigers 'What if'; 1/32 Tamiya P-51D Big Beautiful Doll
Group build:1/48 Tamiya Mustang III; 1/48 Tamiya P-51D Show Bird
    April 2015
Posted by RudyOnWheels on Thursday, February 11, 2016 4:49 PM
Were you spraying from too far away? It can get "pebbly" or dry on the way to the model.... The first time I sprayed MM clear flat lacquer with an airbrush, I had the ratio backwards, I over-thinned it and that will kill the flattening agent and make it dry glossy. I have not had good luck with acrylic clears so far, so I use dull-coat in the spray can. But it is so stinky you need to do it outside or in the garage... Best of luck, Rudy
    January 2014
Posted by Silver on Thursday, February 11, 2016 11:09 PM
Yes you can even on this side of the forum.Very light coats .Let dry for 72 hours .
    February 2015
Posted by panzer948 on Friday, February 12, 2016 8:09 AM
Thanks for the good advice.  Last night I did a little sanding/polishing using the 12000 Micro Mesh pads on only the worse areas where I could see a bit of dust/dirt.  It did mare the surface just a bit, so afterwards I sprayed the entire model again with a few light coats of Testers Lacquer Gloss out of spray can (just purchased earlier that day). That stuff worked much better than the Testor Gloss Coat Enamel I sprayed the night before and dries much faster. But prior to spraying I did do a bit of cleaning around my paint booth; including turning on the fan about 10 mins early and putting down wet newspaper around the surface where the plane was to sit. Wow, what a difference that made. I barely got any debris in the finish this time and the new coat of lacquer covered those areas I polished with no signs of scouring.  Now I am wondering if I shouldn't just polish the whole thing down to remove the rather pebbly orange peel finish that probably started from my first coats of primer thru that bad acrylic gloss coat.  However, that could be a mute point since the gloss coat likely makes the finish below it really jump out at you when the light hits it a certain way. I am hoping this goes away when adding a flat/dull finish at the end.
Some other things I believe I have learned from this experience.
1) I probably should have sanded the primer some before applying my base colors. It was rather rough/pebbly in some places to begin with.
2) Yes, looking back on how I applied the MM Acrylic Gloss thru the airbrush, I think I sprayed it at too high a pressure and from too far away.  I think that caused it to dry prior to hitting the surface and made the coating a little rough.  That would explain why some of it would rub off just by handling the model, which has now created a rougher finish to the model.  Next time I may try the Tamiya Clear Coat (X-22) and just spray it at a low pressure close to the model like I did the base Tamiya colors. I was pretty happy with those base paints and feel I can duplicate that technique with their clear coat product.
So now what to do.... Well my next step is to get these decals on.  If the surface is glossy enough (even with the pebbly/orange peel underneath) to take the decals without silvering then I will call that a win.
So if this model will be eventually sealed in a flat/dullcote finish, will this really be an issue?  Before I spend a bunch of time weathering the model (oil washes etc.) I am going to add the decals to just one horizontal stabilizer and spray it with the dullcote.  That will be a great comparison to see how the model will look when finished while comparing it to how it is now. I am also concerned with my final lacquer based clear coat and putting an enamel based wash on it.  I always thought that a fully cured laquer clear coat (not the base paints) should take some degree of abuse from the compatible thinners; but viewing info on other forums it seems most recommend an acrylic based clear coat prior to weathering with enamels. Any thoughts on that?    I will report back the results!
    January 2003
Posted by CNicoll on Sunday, February 14, 2016 11:51 AM
Thanks for sharing!  Always good to learn from what others are doing and really appreciate the thoroughness of your note.  I usually just use the gloss coat for decaling and most of my models end up under a flat coat so my surface prep is probably not up to what it should be.  Having said that - on my 1/32 Mustang I did do a bit more sanding at prep.  At that scale I think things are easier to see.
Having ready your note, I think I'll work a little harder on my Mustang III I'm current working on.  Have a 2 week business trip but will keep this in mind.
Thanks!  Chris
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, February 14, 2016 4:07 PM
Silver
72 hours drying time between coats is a bit extreme in my opinion. I usually use Rustoleum brand clear coat but spray in 2 or 3 light coats. I let it cure for 24 hours between coats.
    February 2015
Posted by panzer948 on Sunday, February 14, 2016 6:37 PM
Hi guys, just a quick report on what I have been doing.  I am still in the process of putting all the decals on. Should be done tonight (lots of decals in 1/32 scale).  The good news is that I did mask off and spray one area two days ago that was not to received decals.  The Testors Dullcoat from the rattle can did a great job of evenning out the rough paint surface or atleast hiding those flaws.  Also, with the minor light sanding test I did using the MicroMesh pads and recoating it with gloss gives me hope that the finish will not be as bad as I originally thought once I get another coat of gloss (to seal the decals and a final layer after some more light buffing) and the final coat of dullcoat on the model after weathering.  Thanks for the info.
    November 2008
Posted by plasticjunkie on Thursday, February 18, 2016 7:18 AM
I'm coming in late in the conversation but I'd like to throw my .02 in. I have used MM acrylic flat many times with no issues so the gloss one should work the same. I spray at about 12psi and thinned 50/50 with the Universal Acrylic Thinner.
For gloss coats I use Future which works like a charm every time. I like to lightly polish the flat painted surfaces with a soft cotton rag which greatly helps in cutting down on applying gloss coats. I get better results if I hand brush the Future on which produces a glass smooth finish. I apply about 4-5 coats about 10 minutes apart cause the Future dries fast. Then I let it cure for a couple of days then the decals and washes go on. A final flat coat seals up everything.
I will caution you about using a solvent based wash over lacquer as both are solvent based and you may get some reaction. Even though Lacquer is tougher than enamel you may run some type of reaction in some spots.
 GIFMaker.org_jy_Ayj_O
