How do you decide which technique to use
    February 2014
Posted by Caddyshack on Tuesday, February 16, 2016 9:52 AM
I would like to know how many of you decide what technique to use as often there is more than one way to do something.  In particular I'm refering to weathering.  For example, do you prefer the salt application method or hairspray application method...oil washes for panel lines or airbrushing them?  Do you use one technique in some instances and a different one in another or do you have a favorite that you always use?  I'm guessing it's probably a try and see what works best for you kind of thing but I would like to hear others opinions.
This crowd has gone deathly silent, the Cinderella story, outta no where, a former greenskeeper now - about to become the Masters champion. It looks like a mirac - It's in the Hole!
    March 2010
Posted by Nathan T on Tuesday, February 16, 2016 11:50 AM
For me there were a couple of factors at play. Overall, I chose the method that yeilded the best looking results. But other factors were which method is quickest and easiest. Obviously, salt weathering is not quick and easy, and also very messy. I also use a combination of methods, such as post fading the base colors, oil washes/streaks, then post shading shadows and more hightlights with the airbrush, this includes fading out the decals a bit. The flat/semi-matt coat to finish off the weathering. This is how I do aircraft. I'm not an armour guy.
Posted by echolmberg on Tuesday, February 16, 2016 1:08 PM
Hi Mike,
For me, each model is practically a means to experiment with something new.  At work, I have several models on my overhead cabinet.  Several of them depict aircraft with natural metal finishes.  Each of those models was finished using different methods.  One uses a metal powder.  Another uses Model Master metallic enamels.  Another uses Floquil.  Another uses Alclad.  The funny thing is that, even though each one turned out looking differently, I still like all the results.
I tend to pick the techniques based on what I happen to have on hand and also if I'm curious to see how one way looks vs another.  There have been times where I was running low on Floquil so I switched to Model Masters.  There have been times where a plane was very basic in its shape so I took it as an opportunity to try my hand at using foil.  Some methods are more labor intensive or others just might be simpler to do.  I can't say I have a "favorite" but I will say that it all is determined on what my mood is or how much/little I feel like putting into it at that point in time.  It's whatever makes me happy at that moment.
Eric
Posted by Texgunner on Tuesday, February 16, 2016 2:55 PM
Eric, I like your style!  Bow Down
Gary
"All you mugs need to get busy building, and post pics!"
Posted by Don Stauffer on Wednesday, February 17, 2016 8:35 AM
I take it this thread is about weathering?
    February 2014
Posted by Caddyshack on Wednesday, February 17, 2016 8:51 AM
Not so much specifically about weathering but more about what technique you prefer to use and why.
    November 2008
Posted by plasticjunkie on Wednesday, February 17, 2016 12:52 PM
Each model poses a different challenge and usually no two builds have the same identical techniques.
 GIFMaker.org_jy_Ayj_O
