I bought a digital in line psi guage at Harbor Freight. It easily installs on the AB air line. It works ok but is not terribly accurate. (ie. Sometimes to get 6psi i hafta set it on 2.5 ) and it's always a guess and every day is different , but it will stay on the same pressure after fiddling with it to get it right.
I am looking to buy a better more accurate one so I can set it and forget it but that will probably cost 4 times more than the Harbor freight one. I found out the hard way that an accurate psi guage is totaly necessary for AB ing free hand camo and demarcation lines and such.
