acrylic roundel colors
    April 2014
Posted by screwball on Saturday, September 17, 2016 1:47 PM
Hello everyone. Iam building  the revell 1/32 spitfire mk11a and I screwed up the underOopswing roundels. I could not get the decals to conform to the very irregular surface and wound up with a bad crease line on each decal. Even with walthers applied several times I had a bad time. If you have built the kit you know what I mean about the surface. The decals are still on but no future yet. Can someone explain how to avoid these problems with decals. I have only been modelling for 2 years now, but I am willing and able to learn. I understand the basics of decaling but this one stumped me. I believe I'll try roundel masks on this next, and use tape to remove the decals. Any thoughts on this idea? Also, most important.... what acrylic colors would anyone recommend for roundel red and blue. I use Tamiya and Vallejo model air and am not afraid to mix paints. I sure would appreciate all your thoughts and comments. One other thing, which masks will work best maketar, montex, gatormasks....or others?
    January 2009
Posted by fermis on Saturday, September 17, 2016 3:59 PM
I can't help ya on the colors...but I would recommend (to any and all modelers) getting a circle cutter. I have one made by Olfa...picked it up for about 5 bucks at a local craft store (Michaels). It is great for making curved and circle (obviously) masks. For the 5 bucks and a couple bucks for a fat roll of masking tape, you can make masks of any size, without having to spend the cash on a one time use mask, for the rest of your modeling life!
 One trick though....every time I ever tried rotating the cutter, the start and end points never lined up. I discovered that if you stick the tape to a piece of scrap plastic, hold the cutter stationary, rotate the piece of plastic rather than the cutter. I know, it sounds dumb, but it works every time!
    April 2006
Posted by jgeratic on Saturday, September 17, 2016 6:30 PM
I've seen this a popular go to mix using Tamya acrylics:
Dull Roundel Red – Mix of 75% flat Red (XF-7 ), 25% NATO Brown (XF-68)
Blue – Mix of 95% flat Blue (XF-8), 5% flat Black (XF-1)
Yellow – Flat Yellow (XF-3) with a tiny amount of flat Red (XF-7)
Don't have a 1/32 scal Spit, but looking at one in 1/48,  I can see where the decal problem would arise.  Sometimes even liberal amounts of softening fluid wll not help, and you can do the option of masks, or just cut out the problem section and fill the required area with paint - problem now is matching the decal colours.
regards,
Jack
