How to put overhead light into my bookshelf?
    July 2003
Posted by MonsterZero on Tuesday, October 18, 2016 3:32 PM
I want the models more visible. You can hardly see them in there, especially when it gets dark.
    April 2005
Posted by ddp59 on Tuesday, October 18, 2016 4:06 PM
run led strip lighting just behind the face face above your models. can also use battery powered puck lights that use leds but the strip leds will do a broad face of light instead of 2 cones of light.
    July 2003
Posted by MonsterZero on Tuesday, October 18, 2016 4:28 PM
How do I attach the LED strip to the "ceiling" without damaging the wood permanently? I don't want to just nail it in place. That's crude.
    August 2014
Posted by goldhammer on Tuesday, October 18, 2016 6:00 PM
Check out Lowes, Home Depot, etc for self adhesive strip lights. Let them know what you want it for and they can suggest ideas.   I'd mount it under the top at the back and you'll have to drill a hole for the cord to go through, in an upper back corner, whre it is not noticable. Unless you go battery power.
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, October 18, 2016 7:05 PM
One word... Velcro. Lots of it.
    January 2006
Posted by dirkpitt77 on Tuesday, October 18, 2016 9:00 PM
Poke your head inside your bookshelf there and look for mounting surfaces on the inside. Then, if you go to Home Depot or Lowes, you'll find there's a lot of lighting options to inspire you. Sometimes you can look on Amazon or Ebay. I definitely would go with LED lights if I could. They don't throw out much heat. If you can find them in strips as mentioned above, see if it's possible to connect all the strips.
I tend to use small screws to attach any lighting in cabinets. I don't trust the self-adhesive lights to stay put.
You could also do a Google image search for ideas, as well.
--Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    April 2009
Posted by Cadet Chuck on Tuesday, October 18, 2016 9:08 PM
Just don't do like I did and put Halogen lights in there!  They got so hot, one of my best model's engine cowling got permanently deformed from the heat.  Can't believe I did such a dumb thing!  Dunce
Posted by echolmberg on Wednesday, October 19, 2016 9:25 AM
Monster, while at Costco the other day, I stumbled across a set of LED puck lights.  They came as a set of six and you could either turn them on manually or by using a remote control unit that came with the set.  Each "puck" had double-sided foam tape affixed to its back allowing you to stick it to wherever you wanted it.  I placed them in my display cabinet just a couple of weeks ago.  Really works out great!  I think a six-pack was something like $20 or $24.
Oh, almost forgot to mention that you can dim the lights to whatever setting you wanted plus it also had a timer option.  Along with just having them plain old "on", you also had the option of having them on for 10, 20, 30 or 60 minutes (or something like that).
Eric
Posted by Bossman on Wednesday, October 19, 2016 11:08 AM
Not related to the overhead lights . . .  but one way to use existing light would be to simply lay a piece of lighter colored paper underneath the models and let it curve up the back of the shelf a few inches.  Kindof like a photography backdrop.  That would create more contrast between your models and the back of the shelf - even if it were just a lighter shade of brown or beige.
It would work even if you do end up adding overhead lights.
Chris
    February 2007
Posted by mitsdude on Wednesday, October 19, 2016 11:59 PM
ad
ddp59
I agree. I forget the brand but that make a large selection of adhesive hooks that they claim can but removed after applied without damaging the surface. Red/yellow blister packs at Walmart etc. Then string leds min the hooks.
If you aren't too concerned above the cabinet in the area above the models just use led strips with an adhesive on the back. These you can cut to desired length.
Posted by Jim Barton on Thursday, October 20, 2016 11:41 AM
You'd have to drill holes for screws, but you can try one of those plug-in fluorescent lamps in conjunction with the light colored paper on the shelf the model sits on.
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    April 2016
Posted by GlennH on Sunday, October 23, 2016 6:54 PM
Got to say that undercabinet LED tape is unreal! After having seen that once in a clients home above his countertops I was amazed. I'd never suggest strip lights or puck lights again to someone after seeing how these things rock.
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
Posted by Tojo72 on Tuesday, October 25, 2016 7:35 AM
Before I got glass enclosed cases,my biggest enemy was dust,and it could be a losing battle,sure even if you dust regularly it's hard to keep up,and a lot of times your breaking off pieces.IMHO if you can,try for shelves with glass doors.
Just my 2 cents
Also some nice builds there.
    July 2003
Posted by MonsterZero on Wednesday, October 26, 2016 10:01 AM
How to get glass-enclosed cases?
Posted by Texgunner on Wednesday, October 26, 2016 10:17 AM
MonsterZero
Buy them or have them custom-made to your specs.
Gary
"All you mugs need to get busy building, and post pics!"
    July 2003
Posted by MonsterZero on Wednesday, October 26, 2016 10:50 AM
I have no idea where to buy them because it's not an item you find in your average store.
Posted by Tojo72 on Wednesday, October 26, 2016 11:31 AM
Ikea,it's a nice luxury if you can afford them.The low case was built by an old company,they used to advertise in FSM called Gemo Displays,but they went out of business,try Ebay and Craig's List for storage fixtures also.
fox
    January 2007
Posted by fox on Wednesday, October 26, 2016 12:31 PM
Try consignment shops or Goodwill stores. They may be slightly scratched up but easily repaired and at good prices.
Jim  Captain
 Main WIP:
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, October 26, 2016 1:21 PM
Look in stores that are closing or going out of business. You'll find some selling store fixtures and glass cases. Look in used furniture stores too. Sometimes you might find them there. We had a Sears going of out business at a mall last year. I'm sorry I didn't take the opportunity to buy a couple of glass cases then.
Another idea if you notice new jewelry cases had been replaced at a department store, ask the store manager to see whether they're going to toss them or sell them off. Worth a shot.
    February 2007
Posted by mitsdude on Wednesday, October 26, 2016 5:54 PM
MonsterZero
In a furniture store you might ask for curio cabinents.
Pretty sure though you will not find them in a typical furniture store.
Like some have mentioned a store going out of business is the best bet.
Unless you get very lucky you will have to pay a premium for all glass cabinents.
Lots of folks besides us modellers desire these cabinents. Doll collectors, rock collectors, anyone that displays a collection of some kind.
A local store called Hastings is shutting down. They had a beautiful tall, air tight, lighted, all glass display case. It sold for $600. Well worth it but way more than I could afford.
    May 2015
Posted by Griffin25 on Sunday, October 30, 2016 2:16 PM
Watch out for those self adhering over head lights. I heard a bang today and went to investigate. This is what I saw! Just missed!
Griffin
    April 2016
Posted by GlennH on Sunday, October 30, 2016 2:24 PM
MonsterZero
I have not seen the controller part before but yes that is the general idea. You will have a transformer and the LED tape. Just double check on how/if you can cut that tape to the length you need. Obviously I would not cut it until you have done a trial run under the lighting conditions you will be under and how bright you want the display. I was amazed at just how bright and clean this lighting was.
    June 2014
Posted by Tanker - Builder on Sunday, November 6, 2016 5:09 AM
Off Key;
 My cat has a message for your cat . "How could you stand to let your human do this to you ? Where's your dignity ? Shame , Shame " .Cute avatar though ! T.B.
Posted by Jim Barton on Monday, November 21, 2016 3:12 PM
They never seem to work right, either, or at least a few that I had bought some years back at a yard sale and tried them in my kitchen cupboards, which are very dark. Aside from the adhesive failing, they were difficult to turn on and off without a fight, plus they did a poor job of lighting and after just a few weeks, I said the heck with them and chucked them into the trash.
Posted by Jim Barton on Monday, November 21, 2016 3:19 PM
Griffin25
Okay, forgot to add the quote before my post, and I can't seem to get rid of my original erroneous post. Anyway, we'll try it again:
Aside from adhesive failure, these self-adhesive lights never seem to work right, at least some of which I had picked up at a yard sale and installed in my kitchen cupboards, which are quite dark. Aside from the adhesive failing, the lights were difficult to turn on and off without a fight and they didn't give off enough light to make much difference. About three weeks later finally said the heck with it and chucked them into the trash.
