When to apply Bare Metal foil ?
    November 2016
Posted by calmo2 on Friday, November 4, 2016 5:30 PM
Hello; I have not built a plastic model in about 40 years. I have been involved with R/C planes but would like to get back into plastic scale model cars. Thanks to the internet and you tube I have found alot of information on the subject including building techniques and painting with an air brush. I am going to try Bare Metal foiling and was wondering if you put it on after or before you polish you car? Any information on this would be appreciated. Thanks.
    November 2003
Posted by tempestjohnny on Tuesday, November 8, 2016 5:59 AM
Try posting this in the automotive threads you might get a better response
    June 2014
Posted by Tanker - Builder on Tuesday, November 8, 2016 7:13 AM
Calmo2 ;
     He's right about posting it in automotive . But to save you some time . I use the foil BEFORE the final two coats of clear .This way it's been polished , the car body is clean and it also locks the foil in place permanently in place at the fiddly corners where it might come loose first .
      It's okay to put it on and just coat the foil areas with clear , then polish to your heart's content . I have done it all the ways you can think of and that have been recommended . Tanker - Builder
    November 2016
Posted by calmo2 on Tuesday, November 8, 2016 11:56 AM
Thanks. I am new to this site. Now I see where the automotive section is. Thanks again.
    November 2016
Posted by calmo2 on Tuesday, November 8, 2016 12:02 PM
Thanks Tanker-Builder. I kind of thought that would be the way to do it. That way it locks it down to the model. Like I said it has been a long time since I built a plastic model. All these new techniques are some what new to me. I am glad I found this site, I know I will get alot of info from other modelers here . Thanks again.
    October 2006
Posted by kenjitak on Wednesday, November 30, 2016 4:03 PM
I like to clear coat before I apply the foil. While it's true that the foil gets locked down, I think it looks more like chrome trim when it's above the paint.
Ken
Ken
    June 2014
Posted by Tanker - Builder on Thursday, December 1, 2016 8:31 AM
hi Ken;
   In most instances I would agree .I have found though , that some of the fiddly trim ( little tiny pieces) are best applied before paint or clearcoat .This way they cannot come off.
 For instance lettering or door handles etc.  T.B.
    November 2016
Posted by calmo2 on Thursday, December 1, 2016 7:02 PM
Thanks guys; I think I am goint to put the foil on and then clear coat it. Have any of you guys used that Pledge with Future as a clear coat. I used it on my windows but not sure about using as a clear coat but alot of guys on youtube use it. Thanks again.
    June 2014
Posted by Tanker - Builder on Tuesday, December 6, 2016 7:35 AM
Hi ;
    I have for some reason NOT had good luck with Future or any of the product under any new names . I have had it streak and fisheye more times than I care to count .
 Even applying it with an a.b. and getting a nice smooth coat there's those darned fisheyes again . I finally gave up and used a product called GlassCote . T.B.
    November 2016
Posted by calmo2 on Wednesday, December 7, 2016 11:12 AM
Thanks Tank-Builder. I have never tried it but I just got a dual action airbrush and I am going to experiment with it and see what happens. I have some Tamiya X-22 clear but I live up here in Canada and this morning it was 16 below celcius so I do my painting in my basement and I am trying to get away from the fumes of lacquer based acrylics for the winter time. Thanks again.
    November 2016
Posted by Poniatowski on Wednesday, December 7, 2016 11:25 AM
Another thought is to use adhesive for regular aluminum foil. Now, I wouldn't recommend this for bumpers or details, but if you're 'aluminizing' an aircraft or larger areas, it works well and is inexpensive. I used Micro Metal Foil Adhesive by Micro Scale for the entire 1/32 B-17G, then on a 1/48 scale Y1B-17 and it worked quite well. There are how-to articles in FSM.
Welcome to the forums!
Ron
    November 2016
Posted by calmo2 on Sunday, December 11, 2016 12:39 PM
Thanks Ron: I am mainly building car models so I will only be using the Bare Metal Foil in things like around windows a windshields and chrome seperation strips down the side of a car like the 56 Ford Victoria I am building. I have bean building RC planes for the last 15 years and now I am running out of space for all the planes and helicopters I have.Confused But I am retired and I have to pass my time in the winter so I thought I would get back into building model cars. Thanks again.   Cal.
