Hello!
I checked out the sprues one more time and I believe you are talking about the lower wing part being warped. This would be a minor problem, because the top part has those heavy steering surfeces molded, that could act as reinforcement. What I would do is I'd dry fit it and then take lacquer thinner for glue, apply it heavy on the lower part (so that it penetrates a little and softens the plastic), then I'd mate the lower and upper wing part together and just then place the wing in a jig to straighten it out, clamped in three - four spots.
But is it worth it? That Hasegawa A-4s have that nasty dimensional error - the fuselage is much too long! I believe the Fujimi Skyhawks were much better, and you also have the option of grafting on some Airfix parts - the Airfix Skyhawk is a thing of beauty.
In any case good luck with your build and have a nice day
Paweł
