Painting oneself into a corner
    May 2016
Posted by Goat Boat on Saturday, January 7, 2017 10:32 PM
It hurts me to come here and ask this, it really does. but stupid mistakes lead to stupid questions. So here we go...
I have recently finished assembling my 1/72 Italeri Dornier 24 flying boat, and started painting it yesterday. Being primarily a builder of low wing monoplanes, it dawned on me, with much horror, and more than a little too late that the underside of the wing would be nearly impossible to paint now that it's attached to the fuselage!
So here I am with my stupid hat in my stupid hand, wondering has anyone else found themselves in a similar situation, and if so how did you fix it? is there a sneaky way to break the heroic bonds of polystyrene cement? or should I give this thing a viking funeral and start again?
    March 2007
Posted by tonka on Wednesday, January 11, 2017 10:07 PM
I would think you can do some careful masking around the few struts, use plastic wrap for rest of model and just paint the underside. Its not like there is a lot of rigging or a 2nd set of large wings under a DO 24. I'd try that prior to taking it apart or trashing it. Or even simpler,,just leave it the way it is and display it as both a reminder for future projects and because you built it. I doubt anyone seeing it would even notice and if so, makes a great conversation and good for a chuckle or 2
    January 2009
Posted by fermis on Wednesday, January 11, 2017 10:12 PM
Just turn it over and paint away!Stick out tongue
    October 2004
Posted by ikar01 on Wednesday, January 11, 2017 10:17 PM
Have to agree.  Why destroy the kit for something like that?  A little masking where it's needed and the project should be easy to save.  I have to assume that the bottom of the wings, fuselage, and possibly the bottom of the struts would be the same color.
Don't forget to mask off the clear parts, windows, lights, ect.
Posted by Don Stauffer on Thursday, January 12, 2017 9:03 AM
One of the big planning items in kit building is figuring out when to paint each part.  The two extremes are assembling the whole kit first and then painting, or painting each part before assembly.  Normally the ideal is somewhere in between, which I characterize as paint a little, assemble a little, repeat....  Painting each part and then assembling tends to leave visible seams where there shouldn't be any, but assembling completely and then painting risks finding areas that you cannot paint.
Now, each kit is different- you need to look at the assembly instructions and figure out when you paint what, trying to avoid the two problems.  It would be nice if kit mfgrs did a better job in helping with this, but most do not.  In fact, I figure most kit mfgrs figure very few modelers ever paint their kits :-(
Often on high wing strut braced aircraft, I leave the struts off until after painting the major structure, painting struts, landing gear, etc. seperately and adding them after the major airframe assembly is painted.
    June 2014
Posted by Tanker - Builder on Thursday, January 12, 2017 10:17 AM
Hi
 Well ; I would definitely try to paint around the struts using a long handle brush .Now that said .You can always touch up the struts . T.B.
    May 2016
Posted by Goat Boat on Wednesday, January 25, 2017 9:00 PM
thanks for the input, I've been hmming and ahhhing about this for a while. I have managed to free up all but one of the struts, which is right at the centre of the wing. This should give me enough wiggle-room to get an airbrush around most of it, and touch up any missed spots with a paintbrush. I'll throw up a pic when I get some paint on it!
