resin parts
    March 2016
resin parts
Posted by ardvark002 on Wednesday, February 22, 2017 8:47 PM
Hi all, It's me again. How is the best way to seperate resin parts from there bases? There are very heavy, and blades don't work very well, I've found. Have resorted to a fine modeling saw. Any tips? Thxs  Ardvark
    July 2004
Posted by stikpusher on Wednesday, February 22, 2017 8:49 PM
Use the saw to separate the piece from the block. Clean up any remaining excess with sanding sticks or needle files.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Wednesday, February 22, 2017 11:47 PM
Wear a mask and clean up the dusr
    May 2009
Posted by Pawel on Thursday, February 23, 2017 1:43 AM
Hello!
If the pouring block is really massive (square inches to cut through) it's got to be a saw. But if it's a little lighter, I usea so called plastic cutter - like this one:
Olfa PC-S
You use this knive by scouring the surface to be cut with the point of the knive. It cuts a nice, curly swarf or shaving and creates a groove in the pouring block that can go down to the other side of it and allows the pouring block to be safely broken off the part. The cool thing here is that at this point you don't create any dust, just the shavings. This knive is generally nice to have, because it also is good for cutting styrene sheet and can even be used for re-scribing panel lines on models.
Hope it helps - have a nice day
Paweł
www.vietnam.net.pl
    November 2016
Posted by Gerhard on Thursday, February 23, 2017 5:15 AM
Or you can use a cutting disc on a dremmel.
Posted by Don Stauffer on Thursday, February 23, 2017 8:36 AM
Gerhard
Or the little circular saw blade for the dremel.  Also, if you use a hand saw like a Zona or the one from X-acto, lubricating the blade with water helps the cut (either with resin or styrene) as the drag you feel is from slight melting of plastic.  Those saws do not offset the teeth very far for clearance.
