buffing
    March 2016
buffing
Posted by ardvark002 on Thursday, March 23, 2017 8:37 PM
Hi, How is the best way to buff metalizer paint?  What is the major between buffing and non-buffing as far as finish? I think I know the answer, but am going to ask anyway. Thanks Aardvark
    April 2013
Posted by KnightTemplar5150 on Thursday, March 23, 2017 10:02 PM
A soft old t-shirt that is ready to be retired is the most common tool for buffing out Testors' metalizers, but I also like the fabric swatches I use for cleaning my guns to rub out the paint. Inexpensive, disposable after use (metalizer can be messy!), but I don't have to raid the closet. The important thing is a material which is soft and lint free. The only differences between the buffing and non-buffing paints is that the extra work is meant to make a shinier surface. You can actually mix them together for different shades. But, and this is purely a personal opinion, how shiny things wind up really depends on how well you prepare the surface before you spray. Since this brand requires bare plastic without a primer, it's all the more important to get the plastic smooth any shiny before applying paint. The Model Master stuff was alright, but I find it messy to work with and my wife hated the smell, so I switched over to Alclad. Huge difference.
Posted by Don Stauffer on Friday, March 24, 2017 9:14 AM
A number of years ago, there was a fad of polishing the plastic, before finishing, with a brass polish.  There was a brand that was big. I forget now the  brand, the fad kind of faded away and when I ran out of the stuff I didn't buy another can, and stopped doing that, but it did work.  But I started using Alclad which relies on the gloss black, not the bare plastic, so don't need to polish any more (though getting a smooth and glossy enough black finish is still a pain).
    June 2014
Posted by Tanker - Builder on Friday, March 24, 2017 11:28 AM
HI , Don ;
    I have still done  few with A paste like product that is used for Picture frames and such .The harder you buff the shinier it gets .It's called Rub-N-Buff . It works too .And you can clearcoat it without losing the shine . T.B
    January 2009
Posted by fermis on Friday, March 24, 2017 3:06 PM
The "buffing" type will get shinier than the non'buffing. I still buff the non-buffing, just a little. It doesn't make much of a difference, between the two, once you've sealed it and gone on with weathering.
Back when all I had was the buffing type (rattlecan), I turned a new sock inside out and used that to buff. Before I started sealing it...no matter how much I buffed, some would always come off and I'd end up with the stuff all over the decals...it was a mess!!!
Posted by Don Stauffer on Saturday, March 25, 2017 9:32 AM
The brass polish was used before applying metalizer- it was to make the surface of the plastic more glass-like.  As people have noted, there were metalizers that were buffing, others non-buffing, but the polishing with the brass polish was done before the metalizer.
    January 2014
Posted by Silver on Saturday, March 25, 2017 7:42 PM
In the good old days of metal finish was a product called SN'J metalizer powder aluminum.I at the time stocked up on 50 bottles or more.This product works the best.It can be buffed in to 99% of the metal finish products out there.true that Alclad is good but I had no problem outclassing Alclad at model contest local or international.Even Foil did not Stan a chance.SN'J is out of production now.But; other vendors have aluminum metal powder products.Just "google it.(aluminum metal super fine powder).Rub 'N buff is a wax base.Will not stick.
    January 2014
Posted by Silver on Saturday, March 25, 2017 7:45 PM
Search the reader gallery of FSM and you will see my B-58 Hustler and my Mig-15's.My code name is Silver.Ben Zayas of Dupont wa.
    April 2015
Posted by Wolfman_63 on Sunday, March 26, 2017 4:34 AM
The brass polish was called "Brasso". Put a little on a soft cloth like a cloth diaper or old T-shirt, Let the liquid (amonia/alchohol) part evaporate and polish the plastic. Worked great for polishing canopies too. The bad news is around 2008 they changed the formula and it does not work the same.
Website:
David's Scale Models - https://www.davidsscalemodels.com
    November 2008
Posted by plasticjunkie on Sunday, March 26, 2017 6:39 AM
Paper coffee filters work the same as xtra fine polishing pads. I can take something painted with a flat finish paint and buff it with the paper filter to a smooth eggshell finish. I often use this method to smooth out flat finishes before applying gloss for decals.
 GIFMaker.org_jy_Ayj_O
