P-51D air racers
    March 2016
P-51D air racers
Posted by ardvark002 on Friday, May 19, 2017 8:22 PM
Hi fellow builders,  Has anyone modified a 1/32 P-51D into the Red Baron or any other similar plane? I'm pretty sure I'll need a vacumn press to do this. I've found mattel presses on line fairly cheap. Any feedback and tips will be appericated.  Thanks, Aardvark
    January 2009
Posted by fermis on Saturday, May 20, 2017 6:47 AM
I found this...
http://www.oldmodelkits.com/index.php?detail=23072
I've only done one racer..."Galloping Ghost"...but that was in it's early form, no modification required.
Posted by Don Stauffer on Saturday, May 20, 2017 9:24 AM
I am planning a project.  I have the Revell 1/32 Miss America P-51 that I intend to convert to Precious Metal, another unlimited racer.  I found a counter-rotating prop that will work well.  My Vacu-form is too small to do the conversion- I will make firewall forward from wood, carving and filling it before beginning regular painting.  For vacuum forming, you need to carve a master pattern anyway, so for a one-off- no production intent- why not just use the pattern as the part you need (assuming you will not have an engine in it)?
    September 2012
Posted by GMorrison on Saturday, May 20, 2017 2:08 PM
