Cleaning your model
    February 2015
Cleaning your model
Posted by acctingman on Wednesday, July 5, 2017 11:07 PM
Hello
Quick question to you pros about how you clean/prep your model. I've always read that you use warm soapy water but has anyone used makeup removing pads or something similar to clean off the oils from the plastic?
Thanks
    January 2017
Posted by damouav on Wednesday, July 5, 2017 11:28 PM
I tried using them after priming, but sharp parts of molded plastic catch on the pads leaving strands of fine cotton like material to remove.
I would suggest, as you have already discovered to use the soapy water and a new soft toothbrush to clean the parts. If it aint broke, why bother fixing...
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    July 2004
Posted by stikpusher on Thursday, July 6, 2017 3:42 AM
Cotton balls and Polly S Plastic Prep when I do need to wipe down the surface.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Tojo72 on Thursday, July 6, 2017 6:53 AM
I don't.I know many say it's a must,but I have not washed a model other then resin parts and metal tracks,and have had no paint adhesion problems.I do prime my models however.
Posted by Don Stauffer on Thursday, July 6, 2017 9:04 AM
I used to wash each kit, but find today that most kits do not have appreciable mold release agents left on kit parts.  There are a few that still do, but fortunately I have been warned on those kits by fellow modelers and was able to wash them (I use water and hand soap in a dishpan).  Thorough rinsing is mandatory, however, since soap residue is as much a problem with paint adhesion as mold release oils.
    March 2017
Posted by shamoo on Thursday, July 6, 2017 1:12 PM
I have washed in soap and water but our water is so hard it's probably useless. I've switched to using the blue shop style paper towel and IPA to wipe them down first. Use it before painting as well. Nice because it dries quickly
    March 2014
Posted by BarrettDuke on Thursday, July 6, 2017 4:47 PM
AC, The makeup cleaning pads should work just fine. The solution might be a little strong for some clear parts, but I'm not sure. The main concern has already been voiced. You'll need to make sure you don't get the pad snagged on a point and pull out some fibers. They can be hard to see--until you've painted, that is!! I've had times when soap and water didn't get the job done. I use alcohol and previously washed shop rags that have had most of the lose/broken fibers washed out of them. Rags from old bed sheets can work very well for this, too. They tend to have very few lose fibers in them. You still want to prime before using acrylics, though. Barrett
    July 2014
Posted by Bakster on Thursday, July 6, 2017 5:19 PM
damouav
This is my experience as well. Before paint I will use IPA and a balled up piece of paper towel. Doing this can leave some lint too, but it seems less of a problem. Usually, it blows off easily with canned air, or by using the AB.
    January 2017
Posted by ecotec83 on Thursday, July 6, 2017 5:44 PM
I use a dilute solution of simple green degreaser and a semi stiff paint brush to scrub down parts on the sprues. Then I dip them in luke warm soapy water and brush again before rinseing.
