Build steps
    June 2017
Build steps
Posted by jlee9 on Tuesday, August 15, 2017 1:43 PM
Hi ALl,
Thanks for all your previous answers, can someone tell me the basic order of building an AFV model.  I come from doing model cars where I prime and paint and then assemble (except for engine block) in the final steps.  I've been reading and watching, it seems that most AFVs are built up in subsections and then painted?  Am I correct in this assumption?  I'm starting small, and just wanted to paint a primer and single colour and then the decals.  I'm assuming a couple of things:
1.  After primer and paint, I won't need a clear coat? Is this correct?  Or should I do one in a flat finish?
2.  I dont' have an airbrush so it will be done with rattle cans (just a single colour) and the small objects will be brush painted
3.  I was going to prime everything on the sprue to save time as the primer is from a can as well.
Any tips and tricks would be great!
Thanks,
joe
Posted by Bish on Tuesday, August 15, 2017 1:57 PM
Everyone has there own approach. Mine is to assemble everything that is the main colour/colours and then paint. For a tank i keep the turret and hull seperate. I tend to leave the wheels off as well.
You will need to use a gloss coat for decals, but many armoured vehicles only have a few. You could just apply spots of gloss where the decals are.
My best suggestion is to check out some of the armour builds here and you will see a number of ways of doing things.
    December 2013
Posted by route62 on Tuesday, August 15, 2017 2:19 PM
For AFV, I am much the same as Bish, build up as much that is the same color.  Keep turret, wheels, tracks and hull seperate.  I tend to also glue on all the small bits, like tools, tow cables, sand bags etc.  I will go back and with a fine brush paint these right on the model.
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, August 15, 2017 2:28 PM
As Bish already mentioned. Keep in mind, there's no set rule on how you do your build, let alone when and what to paint first, last or whatever. In time, you will get the idea what works for you.
