Model ship display cases
    May 2017
Posted by CMMX on Monday, October 16, 2017 9:49 AM
I have two ships that require 20-22" acrylic display cases. They're not easy to find. Any suggestions?
    August 2013
Posted by Jay Jay on Monday, October 16, 2017 10:09 AM
I make my own out of glass. It's actually pretty easy once you get the glass cutting technique down. Then simply glue the glass sides and top together with clear caulk and let dry for 24 hours.  Applying the caulk cleanly is the hard part but a razor blade does wonders in cleaning up the still wet caulking .
    March 2005
Posted by mfsob on Monday, October 16, 2017 10:49 AM
This guy does excellent work and is very reasonable considering each case is custom built: http://www.grandpascabinets.com/
    May 2017
Posted by CMMX on Monday, October 16, 2017 10:57 AM
Thank you.
    March 2005
Posted by Devil Dawg on Monday, October 16, 2017 9:14 PM
Jay Jay
I wonder if PlexiGlass would work for that? It would be much lighter than glass, and easier to work with.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    July 2003
Posted by ridleusmc on Tuesday, October 17, 2017 8:23 AM
I've been doing some research into this, because I'm converting an old bookshelf into a display case.  Plexiglass would work, and it's inexpensive.  However, it develops a yellow tint over time.  Acrylic does the same job, but without the yellow tint.  However, clear acrylic sheet is a bit more expensive.  I have found some youtube videos on building acrylic display cases.  It doesn't look very difficult, and we, as modellers, already have the required skills.  Just type "acrylic display case" into youtube.  There is a wealth of informative videos.
Posted by Don Stauffer on Tuesday, October 17, 2017 8:37 AM
ridleusmc
I thought Plexiglas was just a trade name (brand) of acrylic.  I know that there are different mixes of acrylic, and it has improved over the years.  Older acrylics suffered from UV damage from direct sunlight.  I know some makers offer "UV stabilized" acrylic.
    June 2014
Posted by Tanker - Builder on Wednesday, October 18, 2017 10:37 AM
I found a good way by accident ;
  One time I was doing some Plexi work . I had a sheet that was going to be a front for a sailing ship case . I laid it on a pipe that was clean stainless . Imagine my horror when I found it was a heating pipe with a stainless cover ! My piece had sagged perfectly over it making a six by twenty four inch gutter shaped "U" . It worked perfectly for a modern warship model after I evened the sides and cut the ends to fit .
 I like Plexi for it's workability and availability . Home Depot always has acrylic sheet for storm doors etc . T.B.
    May 2017
Posted by CMMX on Wednesday, October 18, 2017 10:57 AM
I really appreciate all the good ideas. I'm pretty handy, but I'm lazy about making a case. I'd rather spend my time on model making :-D Strangely, with all the ship models available, the options for cases are really limited. Most are too small (1/700 scale) or too large and very expensive. Thank you everyone.
