DIY Spraybooth
    August 2012
DIY Spraybooth
Posted by Rambo on Sunday, November 19, 2017 9:11 AM
Lets just dive right into this. I went out and bought five pieces of 1/2 2'x2' plywood. It was a bit more that way but it's November in Indiana and it's also comin down rain in buckets right now, so I'm doing all of the cutting on my front porch with a circular saw and jig saw.
  1 The Wood" alt="" />
Ignore the beagle he wouldn't move always has to be center of attention lol. Next was to mark where I was going to cut. So here is how you want to lay it out
  2 The Measurements" alt="" />
After that you want to cut the back plate at 2'x 9.5" then the top that will hold the blower leaving a 2" strip from that 2'x2' to use as the front panel
  3 Sides and base cut out" alt="" />
Clint
    August 2012
Posted by Rambo on Sunday, November 19, 2017 9:26 AM
Next I took it up to my model room, turned the air pressure up to 80psi and hooked up the brad nailer.
  4 Nailing it togeather" alt="" />
Next was working on the blower I picked this up at a good price a few things with it. I only spray acrylic paints if you use enamels you must use a blower that has the motor outside of the airflow. the motor is kinda in the airflow on this one the entire motor is sealed from the air but the housing is in the airflow.
  5 Blower and 2 inch square to 4 inch round" alt="" />
Also had to make my own two inch square to four inch round adapter from things i had laying around
  6 The blower" alt="" />
Clint
    August 2012
Posted by Rambo on Sunday, November 19, 2017 9:34 AM
Next is when I noticed that the blower had no way of hooking to the booth so using some scarp wood and some caulking made a braket to hold it in place. Its just dryfit right now in the photo thats why it looks off center
  7 Blower and Bracket" alt="" />
Next up was building the filter holder I had bought a cheap 12x24x1 filter with out thinking first so i had to trim it down to fit you would want to use one thats 20" to 22" instead
  8 Wood for filter holder" alt="" />
After getting the holder built and caulked i was able to put it up on a card table by the window i'm just using that untill i get something more stable
  9 Temporary table" alt="" />
Clint
    August 2012
Posted by Rambo on Sunday, November 19, 2017 9:43 AM
Now just need to install the filter
   10 Filter in" alt="" />
and wire the motor up now make sure you check the wire guide thats always going to be on these motors and if your not sure get take it to someone who is licensed
   11 Wired up" alt="" />
Last thing I did was took a scrap piece of 3/4" plywood that I used as a subfloor in my down stairs bathroom cut it down to 33" wide to fit in the window. Cut a 4.24" hole in in to take a outside dryer vent hooked a piece of flexable 4" hose to it caulked it now im ready to start painting.
This motor is rated at 175cfm and i've got 4' that I have to run it to the window so thats great. now if your going say 5' to 10' you would want something more in the 225cfm range longer then that again more cfm it all has to do with static pressure
also I need to pick up a piece of plexiglass to use as a top that i can sit a light on so I can see what i'm painting but that can wait till the next time i'm at mendards
If anyone has any questions i'm happy to help
Clint
    August 2013
Posted by Jay Jay on Sunday, November 19, 2017 10:59 AM
TY for taking the time to post all this. Well done.
Is a spray booth purposed only for the removal of  the fumes ?  I don't have much of a fume problem but the "dust bunnies" on my finish drive me crazy. Would a spray booth like this solve my problem ?
    August 2012
Posted by Rambo on Sunday, November 19, 2017 11:43 AM
yes and no the constant flow of air will help. What I do is I keep a spray bottle with just plain water in it and mist around the area I'm painting in that will knock down any dust in the air. If i'm painting for a long time I will do it a few times. The other thing I do is i have a rubber made container with lid big enough for most 1/48 aircraft and 1/35 tanks that has always been kept upside down after painting something I open it up place the model on the lid and click the container down on top to keep any dust from landing on it while the paint drys.
Clint
    September 2012
Posted by GMorrison on Sunday, November 19, 2017 11:55 AM
Nice project!
If you can, set it on a piece of rubber restaurant floor mat.
I missed where you put the switch. That’s always a thing, esp. if you are holding something in your hand.
    August 2012
Posted by Rambo on Sunday, November 19, 2017 12:33 PM
GMorrison
Nice project!
The switch is on the right side of the booth I didn't show how I wired it but it's simple green was the ground for both the cord and from the blower then the Line power was blue the common was brown coming from the blower and the cord was standard code black Line and white for common
Clint
    November 2017
Posted by JerryVa on Wednesday, November 22, 2017 8:25 AM
I have my spray booth so I can attach a front cover with a filter to keep dust out while drying.
    October 2017
Posted by Jay Bones on Thursday, November 23, 2017 12:48 AM
Can't see your pics OP.
When I spray, I have a furnace filter on top of a box fan with cardboard box on it side, shooting into the open and top.  Naturally I cut most of a side away so the airflow will get sucked through the filter by the fan.  Hang what I'm spraying with fishing line (through holes in the top).
Posted by Don Stauffer on Thursday, November 23, 2017 9:24 AM
I figure a top mounted filter gives the best performance, but I wanted a light in the top, so have mounted the filter in the back, angled slightly towards the front, in my current (and last previous) booth.
    September 2015
Posted by Aaronw on Thursday, November 23, 2017 10:10 AM
I built my own booth a few years ago, I also used 1/2" plywood and used a furnace filter. It works well. The nice thing about building your own booth is you can size it to your needs, I figured the biggest thing I'd likely build is a 1/72 B-29 so I sized mine around the dimensions needed to paint a B-29 as seperate wing and fuselage assemblies.
One thing I noticed is it sounds like you are using the common flexible dryer vent hose. It sems like everybody gets those because they are cheap and easy, but those are terrible for air flow. They create something like 10x as much resistance as a piece of aluminum vent pipe. You can increase the efficiency of your blower considerably by using better ducting.
As I didn't have a nice straight shot to the vent I also had to use a flex pipe, but used a short piece of 6" flexible metal heater ducting. It only costs a little more than the plastic dryer hose, and it really increases the airflow of the blower.
I like the idea of misting water before use to reduce the dust, I hadn't thought of that.
I usually turn the booth on a few minutes before I'm going to use it to help draw any dust in the air out of the booth and then leave it running for a few minutes after to ensure all the fumes get out.
I use old desk calenders (the big 2-3 foot type) to line bottom of the booth. One month / page makes a great disposible liner and helps to keep the booth clean. Last years calendars can be found cheap (often free). I got 4 or 5 from the mail room at work that hadn't been used and were getting thrown out so I'm set for several years.
    August 2012
Posted by Rambo on Thursday, November 23, 2017 2:07 PM
That's a good idea for the duct work I got some around here. Also on the liner I was thinking of using a piece glass that I could clean easily after use or something disposal like your calendar idea thank you
Clint
    August 2012
Posted by Rambo on Thursday, November 23, 2017 2:09 PM
Don if I build another I probably will make it a top filter that's a great idea
Clint
fox
    January 2007
Posted by fox on Thursday, November 23, 2017 8:42 PM
Made mine basicly the same only I started with a kitchen cabinet I spotted on the side of the road. The rest is like the one above with an angled filter in the top rear and vented out the window. I had the dust problem while waiting for drying. My wife came in one day and handed me a sheer curtain that fit over the front of the booth. All I had to do was mount the thin curtain rod on the top of the opening and the other on the bottom of the opening. When I'm done spraying, I slide the curtains together and leave the exhaust fan on for a while. Every once in a while, my wife takes them off and puts them in the washer for a cleaning. I was really surprised the first time I saw how the sheers caught all the dust. That's one of the reasons that I'll keep her.
Hope that this helps someone.
Jim  Captain
 Main WIP:
Posted by Don Stauffer on Friday, November 24, 2017 9:42 AM
Rambo
To prevent having to remove and clean the glass under the light frequently, I made tearoff strips to put over the glass.  These are successive layers of transparent tape that race drivers and riders use on their helmet visors, and can remove one at a time when they get dirty.   I just cut several pieces of that clear packaging tape, doubled back a little on the ends to make tabs, stacked them together, and stuck them on the glass. I put five or six on at a time- lasts quite awhile until I have to do it again, and the glass never gets dirty.
    August 2014
Posted by goldhammer on Friday, November 24, 2017 1:17 PM
Might try alum. foil, shiny side up for a bottom liner, would help reflect light to the lower sides of the object being painted.  And can be tossed or recycled when it gets too much paint on it.
    November 2017
Posted by JerryVa on Wednesday, November 29, 2017 12:23 PM
My spraybooth is multi task with my wife spraying some of her crafts with rattle cans. So I have the option of back or down draft or both as the need arises. I can block off portions of each exhaust area as needed. Also not pictured is a baffle on the bottom to open up to further reduce the airflow if needed. Short vent tube and a strong blower keeps up with everything just fine.
    April 2015
Posted by RudyOnWheels on Thursday, November 30, 2017 12:45 PM
OP, I also cannot see your pictures. I had my Uncle's tin-knocker make my paint booth after I designed it. I cannot remember the exact dimensions, but it is pretty big. The filter in the rear is 16x24x1" for reference, and the plane is a 1/48 PBY Catalina. Although not pretty with all the spray foam, I switched out the blower for a much more powerful one I got from work for free. I rolled and welded a 4" duct stub, and installed it in a 1x6" board cut to the size of my window. Everytime I use the booth, I just open the widow. put the board in, and close the window on top. I can spray the nastiest smelliest crap there is, and you cannot catch a whiff of it in the room or house. It is the best thing I ever did. Now I can paint year-round, In the house. Being in a wheelchair, it is a real pain to take kits and parts back and forth to the garage, try not to drop them on the steep ramp in transport, etc. It has increased my modelling enjoyment and productivity 20-fold. The switch on the side controls a fluorescent light, and the blower. I recently started using "press and seal", which is like part saran-wrap and part wax-paper, to protect the inside of the booth. I hope yours works out as well too! - Rudy
    August 2012
Posted by Rambo on Thursday, November 30, 2017 2:06 PM
Wow that is very nice I'm already planning a ver. 2.0 lol with all these great ideas. As for not seeing the photos you might have to update your browser IE don't like to load them but chrome and Firefox work
Clint
    April 2015
Posted by RudyOnWheels on Thursday, November 30, 2017 3:34 PM
You're right, I opened it in chrome and I can see them now, looks like the wood version of mine! Thats a good looking beagle! I love the doggies! - Rudy
    August 2012
Posted by Rambo on Thursday, November 30, 2017 10:36 PM
Glad to hear that chrome worked. He's always got to be the center of attention had him since he was four weeks old when the mother abandoned her pups so he's got some separation issues and hates to be left alone
Clint
