I've used thin plastic sheet stock, (Evergreen,) easy to mark to proper size, then use a compass with sharp blade for cutting through. Also, many packaging containers are suitable for the same. The thinner, the better.
Have tried Saran Wrap, aluminum foil and others, but they seem too thin to allow a reliable compression seal, and they are pretty much a one time use.
Patrick
