Mirror molding-casting
    December 2012
Posted by rmontesb on Monday, July 23, 2018 2:17 PM
Hello!
I've read about creating molds to make resin duplicates of plastic parts for model kits.
Is there a technique to make a mold in order to create a mirror duplicate of a specific part?
One of the halves of a two part fuselage for a 1/72 P-38 scale aircraft is missing/lost. I have the other half, and I wonder if it can be used to make a mold in order to create a mirror duplicate and cast the missing half.
Any help will be appreciated.
Regards,
rmontesbCool
On the bench (2021-08-20): Revell Junkers JU88 A-4.
    September 2012
Posted by GMorrison on Monday, July 23, 2018 2:53 PM
Casting an entire fuselage half is a lot in any case.
Im assuming you have three out of four halves.
Look at it more as a series of sections front to back.
The other corresponding half I would guess is pretty identical to what’s missing except for the wing root area.
Think about making a true copy and then scratch building the wing root area.
    December 2012
Posted by rmontesb on Monday, July 23, 2018 3:35 PM
Thanks!
In this case (1/72 P38 Lightning), the main fuselage halves are relatively small (2.75 inches long and 0.5 inches wide).
If I make a copy of what I have, I'll end up with two right-hand side fuselage halves.
The challenge is to use the right hand side to prepare a mold for the left-hand side fuselage.
Regards,
rmontesbCool
    September 2012
Posted by GMorrison on Monday, July 23, 2018 3:45 PM
Sure, but consider.
There are a total of four halves. Two halves each, left/ right, each port and starboard. Each is different, but mostly in the wing root and elevator attachment point. The engine section, the tail boom/ radiator section and the vertical tails are the same port/ starboard.
    December 2012
Posted by rmontesb on Monday, July 23, 2018 3:56 PM
The only missing part is the fuselage half where the nose/cockpit are located. The engine/tails/boom halves are complete. So, out of six fuselage halves, I'm missing just one.
rmontesbCool
    April 2004
Posted by Jon_a_its on Tuesday, July 24, 2018 6:26 AM
Two things spring to mind:
contact the Mfr to see if you can get a replacement part?
Is this a part that can be replaced by a Resin upgrade part? I'm having trouble visualising that.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    September 2012
Posted by GMorrison on Tuesday, July 24, 2018 8:57 AM
rmontesb
Oh- got it! Well, to answer your original question: not that I  know of unless you can draw it in CAD and order a 3D print. But I dont know much.
    July 2014
Posted by Nino on Tuesday, July 24, 2018 11:03 AM
rmontesb
Hello!
Regards,
The OEM is really the place to go to order the missing part. I hope the kit is still in production or at least not too old.
I ran into same issue with a OOP ship.   It begain to look like it would be a Wall Plaque. Lo and Behold a LOT came on ebay with that very ship, glued together but now I had a part for a paltry sum of $2.53 and a little elbow grease.
You will want to check if any other company used the same mold and watch and wait for a good deal. It's nice to have some spare parts or a kit to practice on.
You could attempt to"Engineer" the part yourself and only display the "good side". A crashed dio might work too.  Planes can bury pretty deep into the ground.  How 'bout a crash thru a hanger door?
   Nino.
P.S. I have a P-38 from way back in the 60's. It was my favorite plane model even if it did not sit flat on the nose wheel unless I put a quarter on the nose. I did not know to put a weight in with the guns- this forum wasn't around to help me then.
