Gerard C.
Hello everybody,
I presented myself to the forum more or less a month ago, and I received very good advice on what to take a look on when acquiring paints and the most usefull things.
Well, the thing is, I haven't bought anything yet. The share amount of things to think about are so immense that even listing them just helps a little.
What I'm trying to say is, I need to know if I'm getting all that I will need at once (avoiding unnecessary postage fees). For now, so you have an idea, I already checked (in order to buy) the following products (and I already own an Iwata Eclypse airbrush):
- Tamiya acrylic paints (both flat and glossy for details)
- Tamiya acrylic thinner X-20 --> this is more of a question, really. Plus, should I add any other product to airbrushing, like Tamiya retarder? and after airbrushing, with which product do I clean the Iwata? with the same acrylic thinner?
Tamiya are good paint but limited in color selection. Why not get Mission Model or Testors Model Master paints.
- Perfect plastic putty - Deluxe materials (for seams)
- Badger's Stynylrez primers ----> I pretend to airbrush it; do I need a special thinner/special product to apply them?
Stick with manufacturer brand thinner until you gain more experience on what works what doesn’t.
- Testors Glosscote and Dullcote (I believe these are the ones I've been told; on a bottle, ready for airbrushing lacquer. Here a doubt comes into mind: I believe I need a lacquer thinner to clean the airbrush; which one do you recommend for testors/is there a testors dedicated thinner?)
Stick with brand thinner to your brand paints. You don’t need lacquer thinner to clean airbrush. I use regular Testors thinner when using enamel paints.
***noob question: is a coat the same as a varnish?º1
Yes
- Then I would like a satin varnish, but I'm not sure if testors also has one
Satin varnish for??? Unless you’re thinking semi-gloss varnish.
- Raw umber from Model Master, and Burnt sienna from Vallejo for washing and finishing (If you think there are better options, feel free to tell me. These are just the main ones my provider has)
---> Considering all this, what do you think I need? My main concerns are the questions I already ask, the things that I need to mix with the products, and the things I need to clean everything after painting (for brushes and airbrush, considering the brands I wrote)
Thanks a lot for the answers beforehand, I feel so bad for having spend a whole month just looking for products and info. I just want to start modelling.
As a couple mentioned, don’t go crazy all at once, buy what you need at the moment when it comes to paint. Do you have Sprue nippers? Tweezers? There are plenty of tools you can get really cheap such as sanding sticks. Don’t waste spending on hobby brand sanding sticks when cheap nail sanding sticks will do. Over time you’ll find cheaper alternative for your hobby needs without breaking the bank.
