I have a quick qestion about spray painting models. What are the steps. And how many coats should i apply thanks.
Z.L
Are you using a rattlecan or airbrush ? Whatever the case,light coats are always best,gradually building up the color until you have the desired coverage.If its acrylic paint,then a good primer can help adhesion and coverage.
If you are using rattle can I have found that letting the can sit in warm water for a few minutes helps the paint flow better.
Ron Wilkinson
rattlecan
You need to wear a mask ,vinyl gloves, and vent the room. It will most likely take more than one session.
LoneWolf13 rattlecan
See my above response then
