I made a mistake when i applyed the primer and theres clumps of spray paint built up on the wing of the model. Should i use sandpaper to sand it down?
Which primer did you use?
I suggest you strip it. Sanding will cause loss of detail, and unless you are really careful, scratches.
I use Easy Off oven cleaner. I don't feel too guilty flushing it down the sink. Or, pour into a bag of used coffee grounds.
If its enamel,lacquer thinner works good,acrylic comes off with alcohol.
grey
LoneWolf13 grey
Which brand/type?
Welcome to the Forums! Glad to have you with us.
Acrylic can also be removed with Windex.
Jim
Main WIP:
On the Bench: Artesania Latina (aka) Artists in the Latrine 1/75 Bluenose II
