Varnishing my spitfire
    October 2018
Posted by gauche on Friday, May 24, 2019 7:54 PM
Hey all,
I'm trying to finish up my first model, a Spitfire MkVb. I've had no idea what I'm doing this whole time, and it hasn't turned out super well, but it's a learning experience and all that.
So I'm up to the varnish stage before I put the decals on. I bought Humbrol Clear (both matt and gloss). For greater authenticity (with what little I know about the historicity), I was intending on using the matt finish until:
  1. I noticed a lot of people online saying it wasn't a great product
  2. I realised it's water-based (I have used enamel paints)
Can anyone give me some advice on how to proceed? Should I forget Humbrol Clear altogether? Is there some other product I should consider using here?
Thanks for helping such a noob!
Tags: decal , spitfire , varnish
    August 2013
Posted by Jay Jay on Tuesday, May 28, 2019 8:54 AM
I admit I havent used Humbrol but being water based shouldn't effect the enamel paint. It's always best to test paint combinations on a piece of cardboard , plastic or a "paint mule" ( a discarded model you're never going to finish ) before using it on a finished model you've worked so hard on. It's well worth the time and effort to do so and it's faster in the long run than striping and repainting your model when after the paint combo doesn't work out.
Having said that, there's two products I use interchangeably, Testor's Dullcoat Laquer ( thinned 50% with hardware store laquer thinner) and Alclad's Aqua gloss. Airbrushed  with very thin coats ,these products have worked well for me not having any problems with any type of paint underneath.  I hope this helps Mate.
Posted by Bish on Tuesday, May 28, 2019 9:08 AM
I haven't used Humbrol either, but you shouldn't have any issues with putting it on the enamel.
    July 2004
Posted by stikpusher on Tuesday, May 28, 2019 11:21 AM
Is your Humbrol Flat coat/Matt Coat labeled acrylic? I have been using their enamel Matt/Flat coat for many years as my go to product. The stuff is excellent in my experience. I thin it with Testors Universal Enamel Airbursh Thinner for best results.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2018
Posted by gauche on Tuesday, May 28, 2019 7:15 PM
Thanks for the suggestions.
stikpusher
It says "water soluble", which I took to mean the same thing (but perhaps I'm wrong about that).
    July 2004
Posted by stikpusher on Tuesday, May 28, 2019 9:31 PM
Good question... my next question is- is the stuff that you have in a tin, plastic pot, or glass bottle? I have the enamel stuff in tins and larger glass bottle.
       - Plankton
LSM
    October 2018
Posted by gauche on Tuesday, May 28, 2019 11:42 PM
It's a 125ml glass bottle.
    July 2013
Posted by steve5 on Wednesday, May 29, 2019 1:47 AM
I've been using both the flat and the gloss for a while now , had no issue's with either ,  I have thinned it with both lacqueur and tamiya thinner's , I have also used it straight from the bottle .
    May 2016
Posted by learmech on Wednesday, May 29, 2019 7:23 AM
You wan to put down a gloss coat (which ever product you decide to use) before you apply the decals. then seal in the decals after they have dried with another coat of either gloss or flat depending on how or if you are going to do any weathering.
