Heat and Models .
    June 2014
Heat and Models .
Posted by Tanker - Builder on Sunday, June 9, 2019 1:08 PM
Hi Ya'll ;
    I know we've talked about this before. This is an update I thought of after I read the latest Scale Talk . I did some further research, and discovered some interesting things about this .
    Here's the findings from my stash and storage shed . I did mention before about an Airfix " E " boat that was an odd color . As you ship builders know this kit early on was almost a light pearl grey in color . Mine was a very brittle grey-green .
     Now checking some older models of another type I was surprised to find a piece of armor , supposedly molded in Desert Tan. It was a deep Caramel Brown!. Same with a motor vehicle molded in Cream. It turned a real pale Muddy Yellow .
 Now here's the twist. The models molded in Silver or if you will,Aircraft Aluminum, were close to Stainless Steel in color with All panel lines a darkened Steel color .They were also very brittle and the clear parts on everything that had them were very hard and Very Brittle .
 This heating and freezing will change the testure of the plastic in that it will harden or slump ( not Melt ) and measuring it against a new model will confirm this .Slumping naturally occuring in areas that are thicker retaining heat and cold longer .
 In many cases with judicious trimming and sanding,you can still build a beautiful model of any of these .It just takes more patience and perseverance to do so . I personally will buy a model wither unassembled or partially done where this is obvious .If it works fine.If not the parts file box gets fuller .
 The one thing I have learned.Surface prep takes longer because some paints don't want to stick to bare plastic that has been there, done that. So, You do have to prime every part with a good primer .I use Rattle Can Rusteoleum Pearl Grey and I will decant some for finer coats with the airbrush .
      Now ,for those brittle clear parts .If you can get some Crystal CD cases for flat stuff an get Vac-Formed canopies and windshields .You cannot polish the very faint yellowish cast out of aged clear .No matter whose kit it is . That's it for now . Bye T.B.
Posted by Don Stauffer on Monday, June 10, 2019 8:18 AM
Clear parts may be acrylic plastic rather than styrene.  Acrylic is a harder, more brittle plastic than styrene by nature.
    September 2012
Posted by GMorrison on Monday, June 10, 2019 8:46 AM
Sheds can wreck stashes.
Posted by gregbale on Monday, June 10, 2019 9:04 AM
GMorrison
So can attics. Super Angry
All those dark-colored shingles to suck up every BTU of solar radiation. Popping them in the toaster-oven would be quicker!
Greg
George Lewis:
    June 2014
Posted by Tanker - Builder on Monday, June 10, 2019 9:51 AM
Okay!
 Who's gonna clean that oven?
    July 2018
Posted by Tickmagnet on Monday, June 10, 2019 1:28 PM
Sounds like a good reason not to build up a huge stash.
    September 2004
Posted by tankboy51 on Monday, June 10, 2019 2:51 PM
Mine is in a cool, full, basement, in low humidity state.
Posted by Tojo72 on Monday, June 10, 2019 4:17 PM
GMorrison
Mine have been packed in my garage/storage unit for a little over a year,its well made,dry,boxes are on pallets.Gets warm but not oven like,really didnt have a lot of choices,hoping for the best when I finally move and unpack them.My completed builds are also stored,anxious to unpack them,probably be another 3-4 months
Posted by Don Stauffer on Tuesday, June 11, 2019 8:33 AM
tankboy51
Ditto
I have a walkout basement, which prevents buildup of humidity.
